A95X Max Plus Amlogic S922X 4GB RAM 64GB ROM Android
    And now for something completely different
    A95X Max Plus Amlogic S922X 4GB RAM 64GB ROM Android 9.0
    5G WIFI BT 4.2 1000M LAN Android 9.0 TV Box with Sensor Gamepad BT Gamepad
    Features: as found
    Main Features
    ● CPU: Amlogic S922X ( quad-core ARM Cortex-A73 + dual-core Cortex-A53 1.7GHz )
    ● GPU: Mali-G52-MP6
    ● RAM: 4GB
    ● ROM: 64GB
    ● OS: Android 9.0
    ● Ethernet: 1000M LAN
    ● WIFI: IEEE 802.11 a / b / g / n /ac, 2.4G + 5GHz
    ● Bluetooth: 4.2
    ● Video decode: VP9 Profile-2 up to 4K x 2K 60fps, H.265 HEVC MP-10 L5.1 up to 4K x 2K 60fps
    ● Comes with sensor gamepad and bluetooth gamepad
    Geekbuying
    Looks like someone finally got around to the thermal chimney concept, should be a cool runner.
      Looks like small electric heater
        wow does look strange hope the remote is something special not like the old boring ones it reminds me of my ouya lol
          It is a small electric heater.
            DDR 4?
            EMMC 5.1?
            Which brand? Gotta be careful about this.
            Where to add SATA/SSD drive? 2.5inch or 3.5 inch?
            Any good APPs that users can sync photos,videos,files by just touching,tapping.
            Since TV box can be powered on always,can be a simple NAS....
            Look forward to seeing a more detailed review,teardown...
              Amlogic S922X
              Based on the Amlogic S922X, it is a 12nm six-core chip featuring Quad-core ARM Cortex-A73 that can reach 2.2GHz and Dual-core ARM Cortex-A53 that can reach 1.5 GHz.
              Android 9.0 OS
              It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
              2.4G Wireless Sensor Remote control
              Come with IR remote control and 2.4G sensor remote control, it supports playing games by the sensor control.
              HDR 10 and 4K Solution
              HDR 10 was first announced by the Consumer Technology Association, a US-based consumer electronics association. Both full HD and 4K TVs offer great picture quality compared to traditional technologies. HDR is being introduced to enhance picture quality further and make things appear livelier.
              Gigabit LAN
              Gigabit LAN provides a data rate of 1 billion bits per second.
              GeekBuying
              $159.99 after coupon: 3PLMDBOJ
                Overpriced!! At maybe $125 or less then it could be a good value and competitive to the other S922X devices, because you know with this brand the firmware will be shit.
                  the older a95 max S905X2 has bay for a SSD this one is huge and lacking drive bay wonder if one could be modded in
                  you would think the USB ports would be out of sight on the bottom or in the back
                  its huge https://www.youtube.com/watch?v=xhJ0q4uFXtk
                    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                    First review
                      Originally posted by Kloeterkong View Post
                      The price with the coupon that he included seems like a very good price at $149.99. However, the problem with the poor Ethernet connection, is a major issue.
                        The guy over at TV Box Stop either has a very natural robotic voice or has some cool voice changing software to keep it nice and neutral.
                          LOL. Think it is a text to speech software program, if my memory is correct the YouTuber TvBoxStop is from the Caribbean so has a very thick accent. He does good videos, so I don't mind the computer voice one bit.
                            New Firmware: 20191011
                            Geekbuying
                              Well here we are at the eve of Xmas 2019, let's do a Xmas story or as we call it a Show and Tell
                              Thanks to GEEKBUYING we can have a close look at the
                              A95X MAX Plus Amlogic S922X 4GB/64GB
                              4K@75fps Gaming TV BOX Android 9.0 VP9+ 2.4G+5G WIFI Bluetooth USB 3.0
                              HDMI 2.1, Adaptive Sensor Remote Control
                              Rather expensive, will it have to goods and support to be the Next Big things well physically it's the next big thing its HUGE
                              All Metal box, HDD/SSD receptacle, and a Gamepad thing
                              They say that the Highlights are as follows
                              Amlogic S922X
                              Android 9.0 OS
                              Gigabit LAN
                              Let's get into this:
                              The Box
                              Within that Box we have More Boxes: guess the box the cat took a fancy too
                              In those boxes we have:
                              Remove the base: place to slip in a 2.5 HDD/SSD
                              More Digging into this:
                              More parts than boxes:
                              HDD/SSD receptacle/caddy:
                              Top Side of PCB:
                              Boring Underside PCB:
                              Beefy enough Plug pack:
                              Ports:
                              WiFi Chip:
                              SSD/HDD interface stuff I think:
                              Now to put it all back together:
                              Geekbuying
                              More later after lots of Egg Nog:
