Rockchip RK3229 Android 8.1 atv firmware (wifi 8703)
    This is Android 8.1 atv firmware for Leelbox Q2 PRO S which perfectly works in this box.
    My TV BOX: T95D Android TV Box Rockchip RK3229 Quad Core BT4.0 RAM 2GB DDR3 ROM 8GB 2.4GHz
    Wifi Chip - RTL8703BS
    Printed on PCB Board:
    T95N-RK3229_512X8
    20170706_V1.8
    Pictures are here:
    Hi Everyone We have created this thread to collect all the NAND pin Short to Mask ROM Mode locations for all our members. Because firmware comes on android
    Enjoy.
    Rom:
    https://mega.nz/#!5OJ3XQwD!d-H1Z5SYC...luKHr0mZwAW0ac
    Driver Assistant _v4.5 :
    https://mega.nz/#!oiRDBYoQ!9VQdfDzsC...1TXAPTrlPk1-cc
    AndroidTool:
    https://mega.nz/#!ZHpUCQBb!XO0-nHT8f...3ScB5rNTVH8Ldw
    Video :
    https://mega.nz/#!4uZijSST!L-8crIEih...hxPnHndTjxmOmY
    Any reason you post this same message in every rk3229 thread?
    Maybe you should open a single thread with your device model and post all the tips, tricks and info about it there?
    Just a suggestion
      Just a suggestion
      You are right and I would consider this next time.
      I am going to delete those other posts and refer to this post only.
      Regards
        V88 2+16TV box does not work
          my device is h96 rk3229 1GB?I don't know if it works?
            I upgraded successfully! thanx hannah
              MXQ PRO 4K 1GB RAM SV6051 Wifi not booting got only Red LED
                T95N-RK3229_512X8
                20170706_V1.8
                Pictures are here:
                Enjoy.
                Rom:
                AndroidTool:
                Video :
                There is no volume up and down function, can you fix it?
                  Can i install it on T96R tv box ?
                  Board: XT-MX4M-V13
                  Proc: RK3229 Quad Cortex-A7
                  Wifi: RTL8703BS
                    Board: XT-MX4M-V13
                    Wifi: RTL8703BS
                    I do not have that box so I cannot answer but it looks like you have the correct Processor and WiFi chip for this ROM to work.
                    If you are successful please report back here and it may help others.
                    - Hannah
                      hannah I have the same box as you. The ROM works great! Just kinda wish the clock worked. Can it be added if rooted?
                        Cannot boot to recovery. Don't think it can be rooted.
                          work like a charm thanks Hannah
                          ps mxq pro 1gb /8gb
                            How to change remote config? i have different remote. here my box and remote, Bluetooth and remote not working
                            Thanks before
                              Hi Hannah,
                              Please refer to your post.
                              I have T96R tv box with Rockchip RK3229 A7 Cortex CPU with 2GB DDR3 RAM and 8GB EMMC Flash with Android 6.0.1 version OS. I hope your uploaded ROM will work for my box to update the OS version. The box has a reset button which can be pressed with toothpick or a pin.
                              There are 2 queries
                              1. Is it mandatory to short the pins on the motherboard? why I'm is because there is reset button available. Can I use reset button instead of shorting pins?
                              2. How to backup the device, if the firmware up-gradation is failed?
                              Thanks in advance.
