https://www.aliexpress.com/item/4000...chweb201603_53
New S905X3 box with dual wifi for around 40 dollars us? wow if its the truth that is
I came across this box while browsing aliexpress, S10 MAX+ Android 9.0 Smart TV BOX Amlogic S905X3. and it's priced around only 40 bucks u.s. I wonder if it's a genuine with the actual chip that's advertised, if it is then, it seems like a pretty good deal.
https://www.aliexpress.com/item/4000...chweb201603_53Last edited by mike808; 04 September 2019, 13:33.Tags: None
S10 is one of those no-name generic brands with no support, the hardware may be decent with the S905x3 but you are really gambling if the OS software will be decent or even remotely good. Better off just putting in a pre-order for the new $50-70 Khadas S905D device. Unless you're a tv box seller then yeah buy 1000 of these cheap boxes and tell your customers you don't offer any warrenty or extended support for these devices lol.
I've ordered one piece and should have it sometimes next week. Looking forward to testing how it works. I'm guessing the firmware is no better or worse than any other Chinese box manufacturer like Tanix or Beelink, they all have their issues, as long as they're functional and can play up-to 4K videos I'm happy.
I received the box today, was quiet surprised, it came earlier than anticipated. Anyways, from initial use of the box, it seems to be pretty stable and snappy, and very smooth, plays the highest bit-rate 4k videos on youtube without any trouble, very smooth playback, and good picture quality. The only issue I noticed was that the upper info/curtain bar can't be dragged down, which might get fixed with a firmware update. Other than that, it's pretty good, I was able to turn off the touch sound from settings unlike the TX6 box that you basically have to put in do not disturb mode to turn the touch sounds off. Also, there is an option for dolby digital video under display settings, I don't know if it actually makes any difference in the picture quality, but it's there. The box runs pretty cool too, stays below 50 degrees Celsius. Kodi, stbemu, smart youtube, etc., work flawlessly, no crashes or reboots even after a few hours of continuous use, has dual wifi and bluetooth, most of the settings are easily accessible and it's rooted. There is actually a root switch in the settings that on can turn on and off. Also, the box is pretty small in size as well.
Sounds decent, but don't expect any updated firmwares from the manufacture, the notification curtain is problem for all the latest Android 9 Amlogic devices. And I never noticed the "Touch sounds" setting from the TX6 latest firmware not being accessible or that being an issue for me in device usage.
If the notification curtain is an issue for all Android Pie Amlogic devices then, it's not a big deal if this device has the same issues, which doesn't really affect in any way the performance or functionality of this device, I'm sure there will be a fix out in due time. Other than that, after using this box for a couple of days now, I can definitely recommend it based on my experience. No crashes or reboots everything is super stable and works as it should, this box uses the leanback launcher, which is very customizeable, I would recommend this box or the Tx5 Pro over the Tx6 box, as these both are based on Amlogic chipsets and both play 4K highest bitrate content on youtube flawlessly, which the Tx6 can't do. Also, I find this box is much faster than Tx5 Pro as well, it gets an Antutu overall score of around 59000, which is higher than what the Tx6 and Tx5 get. For around 40 bucks u.s. it's a pretty sweet deal in my opinion, and if there aren't any problems with the current firmware, why ask for updates, updates are only needed when current firmware isn't good, which is not the case this time.
Originally posted by trebor View PostLets have some pictures and info who be good,
AliExpress Shopper 06 Sep 2019
TV BOX Plug Type:US Plug
"Good fast box, firmware needs a bit of improvement, as cpu z and aida64 show the cpu to be cortex 53 not 55 as it should be because of the s905x3 cpu. Also, the top notification bar cannot be pulled down, hopefully these issues will be fixed in next firmware release. Otherwise box runs fast and cool and video playback is very good."
" "Edit~ had several pictures downloaded ready to go from the website, but I'm not allowed too attached a web p extension dot-... apparentlyKris....don't forget my boxes! Okay?
All Good...
C'mon fellas I don't get every box that is made and do my best to show and tell whats on the inside to help others to see the good and the bad and sometimes ugly
If you are going to mention a box then at least do a bit of a show and tell its not hard
Just do it....or well the thread may just be deleted
Yes, please delete this thread as I won't have any time to open up the box and post pictures which I'm not getting paid to do. I don't wanta risk damaging my box by opening it up without any reason, also we don't want to upset your sponsors by saying anything good about similar boxes with same chipset and features that are selling for half their price. Abut posting pictures of the cardboard box and what's inside, it's the same as any other chinese made tv box with everthing the same, hdmi cable, remote and power adapter, this doesn't have any special surprises, so it's really pointless to post pics, and for those interested you can get pics on the sellers website and there are a couple of unboxing videos on youtube as well. I'm not a professional reviewer and don't get free boxes or get paid to do biased reviews.
"also we don't want to upset your sponsors by saying anything good..." and " and don't get free boxes or get paid to do biased reviews"
What are you insinuating here?
Many cheap devices enter the market, some are decent deals, some cut corners in areas not easily seen. Some examples of cutting corners, no HDMI port protection, substandard components like caps, ICs and some lack proper ESD protection circuits. Most of those can come back to haunt a user. I am not saying any of this is the case with your box. A teardown is one way to know or at least get an idea.
There are currently 1551 users online. 0 members and 1551 guests.
