TWRP 3.2.2 with DongleStick X96S ( android 9 PIE )
    first of all, thanks ViT (atvxperience).
    For the time being, just boot, ( no install ).
    The source of the file TWRP : https://forum.atvxperience.com/viewt...c4b3a6a47f383b
    Copy file "TWRP_322 (1).zip" in sdcard externe.
    1) Reboot the X96S with reset bouton or TERMINAL : reboot recovery
    2) in recovery android, Apply update from EXT (ENTER), Update from sdcard (ENTER), TWRP_322 (1).zip (ENTER).
    Do not forget, you are responsible for your handling, so be careful.
    Other use with file TWRP IMG.
    ATTENTION ( just experimental ), it is possible to install it, he works, but after reboot system, there is the continual loop, you should reinstall the firmware or ROM.
    thanks mojojojo67.
    The source of the file TWRP : https://forum.freaktab.com/forum/tv-...2-u211-devices
    Take file, android 9 TWRP ->
    Does that backup and restore Vendor Partition? Because I believe it does not, only the newer TWRP versions do 3.2.3 and above.
    Did you see I had already posted a modified TWRP: https://forum.freaktab.com/forum/tv-...473#post782473
    It is not permanently installed because of the System_Root+AVB-verity security blocks, but Vendor is backed up and restored properly.
