MXQ CUBE S10X AMLOGIC S905X 2G /16G ROM with VOICE REMOTE ATV O/S 7.1 DUAL WIFI BLUETOOTH
    Specifications as found:
    Model No. ACEMAX MXQ Cube
    CPU Amlogic S905X Quad-Core 64-bit Cortex-A53 up to 1.5GHz
    GPU Penta-Core Mali-450 up to 750Mhz+
    ROM 2GB DDR3
    Internal Storage 16GB EMMC
    Resolution 4K(3840 X 2160) up to 60Hz
    OS Android 7.1 ATV
    Video&Audio Format
    Support Decoder Format VP9-10/H.265-10/MVC/MPEG-1/2/4 VC-1/WMV/AVS/AVS+/RealVideo/MJPEG/H.264/JPEG
    Support Media Format Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
    Support Music Format MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
    Support Photo Format HD JPEG/BMP/GIF/PNG/TIFF
    OSD type of languages English/French/German/Spanish/Italian/ etc multilateral languages
    Output & Input
    USB host 2 High speed USB 2.0 (1 OTG and 1 HOST), support UDISK and USB HDD
    Card reader TF card
    HDMI HDMI 2.0a transmitter With 3D, HDR, CEC
    LAN Ethernet:10/100M, standard RJ-45
    Wireless 2.4G/5G (802.11b/g/n/AC) WiFi +BT
    Bluetooth Support
    Speaker 2W speaker
    MIC Digital microphone, 3-5 meters far field voice collection
    Others
    Power Supply DC 5V/2A
    Accessory Remote control, User manual, Power supply, HDMI cable
    Options Support mouse and keyboard via USB or BT
    Support 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle
    Thanks To Acemax to day we have a look at the:
    Very small Media player with a Built in Speaker and other goodies we are about to find:
    They state the Following:
    SUPPORT NETFLIX 4K
    CPU:Amlogic S905XQuad-Core 64-bit ARM Cortex-A53
    GPU: Mali-450 5-Core
    OS:Android 7.1 (Androidtv OS) ATV
    2GBDDR3 RAM, 16GBeMMC ROM
    Card reader: Micro SD card slot
    Support the latest HEVC (H.265) decoding
    Support 4K60fps Super HD video
    Wifi: IEEE 802.11b/g/n, 2.4G/5G Dual Band
    BluetoothWireless Connection
    Wired/wireless mouse/ keyboard supported
    So lets have a look see to what we have:
    Box and whats in the box:
    Ports
    Speaker in base
    Pop the lid: Thermal Pad on speaker (plastic) its the thought that counts
    Close Look PCB:
    Upper: 905x CPU
    Under:
    Lets put this all back together and see what it can do and has to offer, dare looks like its a compete to the Google Home or Alexa units
    Could be fun more as it happens..
      All Fired up good and easy, Google etc, all Apps updated from google.
      Running ATV v 7.1 all up todate and works well for what it has to offer.
      Box appears to fairly Zippy and doing as you would expect
      Just a quick look for now etc, had to check out the speaker and stuff, all OK.
      Voice remote works as intended so and works pretty well as remote, also using Logitech k400 ok.
      UI
      System info
      Installed apps, no junk in this trunk
      DRM:
      Looking Good on Flix as stated
      Audio from Speaker, loud and clear here, recording with phone does not give true level Clear and sharp
      Nice and loud handy for the Hello Google experience if that floats ya boat
      Option in settings to use speaker on or off as seen
      Not to bad at all
        many thanks for your kind reviews, Trebor.
        any guys interested in this model, can send us messages or emails for inquiry.
        ACEMAX
          It's an old SOC, old Android version and no NPU for AI.
          I'm afraid that this is little more than a gimmick,which I suspect that few will show real interest.
          Bring the tech up to current levels and then you might stand a chance of selling them.
          • trebor
            trebor commented
            Editing a comment
            Like yourself there is a still a lot of old tech out there that has some use, works well if its not broken why fix it.
          905x much more stronger than 905w , 3318 etc.....and also more stable .....
          • trebor
            trebor commented
            Editing a comment
            Yep All good Points to note
            The 905x has proven itself
            These wizards sometimes go off withe the fairy's I think
          this is a decent box for about 28 del.....its stable with no crashes or reboots etc got it cos that lets crack on guy said it supports netflix hd/4k etc er.......it doesnt...it may have 4 weeks ago but it just says error etc it might have been blocked....hope theres a fix but dont hold your breath....dstv now works fine tho....there are better boxes than this one but at this price...its worth a go for sure...
            Yep Netflix are cracking down yet again but as you say, neat little unit for the price,
            More to the world that just Netflix handy to have, but a fully certified box is not a lot more if Netflix is you Need.
              All these Amlogic boxes claim that they support the VC-1 codec, but none do.
                Need firmware
