(ROM) Minixfreak_OS "H96_Max_X2 S905X2
    Minixfreak_OS
    Only For H96 Max X2 and Hk1 Pro
    Changelog
    -AndroidTV
    -Mashup firmwares (H96MaxX2, Gt1 and x96Max)
    -Init.d enabled
    -Build.prop Tweaks
    -Preinstall apps (Es file explorer, dark media iptv(Amazing Service), kodi 18.4)
    -Smooth and fast
    -Twrp recovery
    Tips
    -Android core tv service notifications, when playing anything a notification comes up at the top , go to settings then apps then look for androidtv core service and disable notifications... some people like it all depends on your taste.
    -You can root with magisk zip through twrp recovery
    bugs???
    Dont think so but feel free to let me know
    Download link:
    Enjoy everyone and sorry i havent been around , ill be working on gt king and rockchip devices soon so stay tuned ... my newly born daughter keeps me very busy so please be patient
    We miss you around here your work is awesome I appreciate you work
      Error USB burnig tool Key file configurate wrong
        U need the lincense file for h96 max x2 ... Its easy to find
          thanks I installed the ROM, when the device is off, the remote cannot the turned on
            Have to look into it
              Can this rom be flashed in x96 max
                I wouldnt . but it might work ...
