Hi everyone. I'm new here and I'm trying to install the TWRP for H96 max + version 4 / 64gb HS2734 chip but I can't install. I searched everywhere for guides or files and found a TWRP for Rockchip R3328 but I went to Brick the device. Then I solved it by reinstalling its original firmware. I had tried with the Flashfile application but everything got stuck. Can you help me with this? I would like to install the Magisk but if I don't put the TWRP I can't do the procedure. Thank you all.
H96 max + versione 4/64gb Android 8.1 HS2734 and TWRP install
Hi everyone. I'm new here and I'm trying to install the TWRP for H96 max + version 4 / 64gb HS2734 chip but I can't install. I searched everywhere for guides or files and found a TWRP for Rockchip R3328 but I went to Brick the device. Then I solved it by reinstalling its original firmware. I had tried with the Flashfile application but everything got stuck. Can you help me with this? I would like to install the Magisk but if I don't put the TWRP I can't do the procedure. Thank you all.Tags: None
Originally posted by nappi9 View PostHi everyone. I'm new here and I'm trying to install the TWRP for H96 max + version 4 / 64gb HS2734 chip but I can't install. I searched everywhere for guides or files and found a TWRP for Rockchip R3328 but I went to Brick the device. Then I solved it by reinstalling its original firmware. I had tried with the Flashfile application but everything got stuck. Can you help me with this? I would like to install the Magisk but if I don't put the TWRP I can't do the procedure. Thank you all.
It's supported by Rockchip Android Pie since November last year.
You won't find a working TWRP for your device and even if you do, flashing Magisk won't work and cause a bootloop as the manufacturer has to enable it in the firmware first.
Ask the manufacturer to build Magisk into the firmware.
There are currently 1490 users online. 1 members and 1489 guests.
