Radxa RockPi 4 RK3399 - Custom Android Pie firmware by mo123
    Device arrived, i have installed your 1.5 ROM works nice so far, what advantage has android 9 for a tv box?
    might stick to android 7 idk, what version is normal android? 1.0 and 1.1?
    i have an nvidia shield for ATV so this will be used for normal android multimedia
      BTW could add nu.nav.bar (playstore) to your rom, i think overlay apps perform better than real android navigation bar, less stuttering
      • mo123
        mo123 commented
        Editing a comment
        nu.nav.bar added to v1.4 firmware.
      #18
      Thanks for letting me know of that app, will use it in future.
      I also asked the developer if he could add more features to the app.
      I will try to make a tablet Android 9 firmware soon.
      Android 9 has auto frame-rate switching, HD Audio passthrough, Magisk root/hide root support which don't work correctly in Android 7.
        Okay auto framerate is nice to have,
        No problem, i have more useful apps to include.
        - nu.nav.bar (ofc) can set to open quicksettings menu if no dropdown is present in firmware
        - Mobilism Market (must have)
        -SD Maid
        -Firefox Nightly (supports opening in second tab ect. maybe can done via firmware aswell, opera cannot open links in second tab)
        -Spotfiy (pref from Mobilism without ads :-)
        -XPosed
        -GravityBox
        -Liveboot boot animation (looks nice on big screen)
        - Kernel Auditor
        -Fake Wifi (for ethernet spoofing)
        -QuickPic ( useful for WIFI FIle Transfer and also best gallery app there is a REMIX on XDA)
        -Tubemate Downloader
        -Launcher10 (see Screenshots)
        -Blokada Ad Blocker
        -Total Commander
        -Gboard
        -Youtube Vanced default system apk
        The Kernel Govenor should be set to PERFORMANCE by default, maybe could include CPU overclock in the kernel? would be nice to get the max out of the chip with cooling
        Set FORCE GPU Rendering on by default in firmware, improve video playback at the cost of more power consumption
        Disable Android animations, i found that 2,4GHZ mouse cause more micro stuttering in video playback, most tv box (beside a5x max mx9 pro) seem to have a lot micro stuttering in youtube playback, modern android TV have framerate interpolation so those stutter get doubled up and it looks bad, disable Statusbar in android firmare, its not really useful and causes playback stuttering and keeps showing in some apps while watching.
        For MINI keyboard (Rii ect.) i set up keys to perform actions: (used Gravitybox)
        -hold back key -->switch to previous app
        -double tab back key --> kill visible app on screen
        - adjust size of quicksetting titles
        Could add some codes to the android calculator app to unlock some DIY developer menu (example for enable overclock, root ect. or for PCBA test app)
        Maybe something is interesting for you to include in the rom, would beta test if needed, i have not yet setup the rockpi with a firmware waiting for your custom rom
        My main fokus on those tv boxes is videoplayback it has to be fluid on 4k tv, the H96 Max for example is so damn bad at that i sold it right away lol
ID:	797394Click image for larger version
ID:	797395Click image for larger version
ID:	797397Click image for larger version
ID:	797396Click image for larger version
ID:	797398Click image for larger version
ID:	797399Click image for larger version
ID:	797400Click image for larger version
ID:	797401Click image for larger version
ID:	797402Click image for larger version
          Oh BY THE WAY, the only official site for youtube vanced is : vanced.app
          risk of malwareon other sites!
          • mo123
            mo123 commented
            Editing a comment
            Youtube Vanced added to v1.4 firmware.
          #21
          Flash with Balena Etcher to a micro-sd card and see if it boots and works for you.
          @mo123,
          Many thks bro, it's work !!!
          Found Wifi can't turn ON, always auto OFF in 1~2 secs while turn ON. Any Idea ?
          • mo123
            mo123 commented
            Editing a comment
            Then your device's wifi is not supported.
            RockPi 4 uses AP6256 wifi.
          #22
          The flash options is really nice feature of the rom
            Is it supposed to happen? i have red led blinking on my 1.3V of the board
              Updated OP with v1.3 & v1.4 firmware info.
                Still working on full android rom for the device?
                waiting for it so i can flash my rockpi to use for home multimedia
                  @mo123,
                  Tried boot Ver.1.4 on from, but stuck at RockPi first screen
                  tried again with another SSD, still same
                  (Ver. 1.2 worked fine before)
                  Still have to say many thks for your great effort !!!
                    Originally posted by lliou View Post
                    @mo123,
                    I have v1.3 on emmc and put v1.4 on a micro-sd card and it boots properly.
                    But some users also say just v1.4 micro-sd card booting has some problem.
                    It might be because I added USB booting, it seems USB booting only works if firmware is flashed to emmc, then you can use the bottom USB 3.0 port for LibreELEC/Armbian.
                    So I hope to get a newer u-boot in future so you can use any booting method easily.
                      @mo123,
                      Many thks for reply promptly
                      well... What I can do now is waiting for your new version.
                        @mo123,
                        Please test 1.4 firmware for sdcard booting troubleshooting
                        Newer u-boot(also has nvme changes)
                        Also test this one on nvme(for people that use nvme storage)
                        Older u-boot
                        https://mega.nz/#!oFExhKZJ!YneWFMSVbbLltVEZ5HzoPoqllvuxByVMGylgh0q 3U0U 1
                        If the 1t one is not booting, try the 2nd one.
                          @mo123,
                          Tried frist one and worked !!!
                          You are so cool !!!
                          Do you still working on full Android version ?
