CUBOT X20 PRO // 6.3 INCH // FLASH SALE @ GEARBEST // New Affordable Flagship With a Touch of iPhone Design
    Hello Freaktabber,
    Meet the new CUBOT X20 Pro Flagship with a touch of new iPhone design.
    Cubot X20 Pro is the next affordable flagship phone with AI SoC and Triple camera system.
    Helio P60, 6GB Ram+128GB Rom, AI triple camera.
    Cubot X20 Pro is released in the month of August 2019. The smartphone is powered by MediaTek Helio P60 (MT6771) Processor.
    It is packed with RAM of 6 GB and ROM of 128 GB External Memory Supports Up to 256GB (Uses SIM 2 Slot).
    The Cubot X20 Pro runs on Android 9.0 Pie operating system which makes the experience better.
    Sometimes there are rarely moments where it is difficult to understand the device is a tablet or a smartphone and this is one of the moments.
    It?s Display of 6.3 inches IPS that gives a resolution of 1080 x 2340 Pixels, 24-bit. The smartphone is fueled with 4000 mAh, Li-Polymer battery Capacity.
    The camera has main and rear camera 12MP + Secondary rear camera 20MP + Third rear camera ? 8MP.
    Brand CUBOT
    Model X20 PRO
    Device Type Android 4G Smartphone
    CPU Octa-Core 4 x 2.0 GHz ARM Cortex-A73
    4 x 2.0 GHz ARM Cortex-A53 CPU Clock
    Chipset MediaTek Helio P60 (MT6771), 64-bit Processor
    GPU ARM Mali-G72 MP3, 3 Cores, 800 MHz
    Camera Triple 20MP+12MP+8MP with Dual-LED
    AF Rear Camera | 13MP Front Camera
    Memory RAM- 6GB LPDDR4(X), 1600MHz | ROM 128GB
    Display Screen size 6.3-inches IPS FHD+ Display (1080 x 2340 Pixels) 24-bit
    Battery 4000 mAh Lithium-Polymer
    Sensor Proximity Sensor, Accelerometer, Light Sensor, Compass Sensor
    Fingerprint Sensor, Gyroscope
    Color Black, Rose Gold, Ocean Blue
    Operating System Android 9.0
    I/O Ports 1x Nano SIM Card Slot, 1x Nano SIM Card Slot or microSD/TF Card Slot,
    Type-C USB Port, Audio Out Port, Power Button, Volume Button, Microphone, Speaker
    More Features Metal Frame and Glass Body Design, EDGE, EV-DO Rev.A (1.8 Mbps UL, 3.1 Mbps DL), GPRS, HSPA plus, LTE CAT 7 300 Mbps DL, LTE 100 Mbps UL, UMTS, Computer Sync, OTA Sync, Tethering, VoLTE, Rounded Edges, GFF Full Lamination, OTG Support, Secure and Fast Fingerprint Sensor.
    You can buy it now for only $149.99 @ GEARBEST FLASH SALE.
    I wish this would work on AT&T in America.
