TR99 S905X2 4GB RAM 32GB EMMC (ROM / Storage)
    Hi I just wanted to share a few pictures of this box and tell you some details (and maybe open a topic for it if it is needed)
    Click image for larger version  Name:	 Views:	0 Size:	133.7 KB ID:	784079Click image for larger version  Name:	 Views:	0 Size:	132.6 KB ID:	784078
    Click image for larger version  Name:	 Views:	0 Size:	84.8 KB ID:	784080Click image for larger version  Name:	 Views:	0 Size:	100.9 KB ID:	784081
    Specs:
    SOC: Amlogic S905X2
    RAM: 4GB SpecTek DDR4L (PS082-062 BT)
    EMMC: 32GB Samsung (KLMBG2JENB-B041)
    WiFi: AP6255 433Mbps
    Ethernet: 100Mbps what is integrated into the SOC (I think it is the same in the 4/64GB version also)
    The Ethernet port is advertised as "1000M" ( 1000Mbps / 1Gbps ) but in fact it is 100Mbps.
    Technically it is working correctly, I tested and reached 60/95Mbps (Down / Up) on Speedtest.net and on Fast.com (Yes, the Down speed was slower for some reason with the android apps)
    I also tested the LAN speed and reached 95/95Mbps (Down / Up) speed on FTP
    They might give you the excuse that they meant the WiFi is 1000Mbps, but it is 433 Mbps. Here are my test results:
    230/230Mbps (Down / Up) on Speedtest.net and on Fast.com
    I also tested the LAN speed, but because of the limitations of my "FTP server" I reached 95/95Mbps (Down / Up) speed on FTP
    I tried a TP-Link UE300 USB 1000Mbps network card, it was recognized and it was working "plug and play"
    70/210Mbps (Down / Up) on Speedtest.net
    160/220Mbps (Down / Up) on Fast.com
    You may only view thumbnails in this gallery. This gallery has 4 photos.
