Item | Description | ||
Dimension | 119mm*119mm*17.9mm | ||
Weight | Only Device 0.38 kg | ||
With Accessories kg | |||
CPU | S922X-H Quad-core ARM Cortex-A73 and dual-core ARM Cortex-A53 processor | ||
Graphics | Hexa-core ARM G52 MP6 Graphics | ||
Amlogic Video Engine (AVE) with dedicated hardware decoders and encoders | |||
Support multi-video decoder up to 4Kx2K@60fps+1x1080P@60fps | |||
Supports multiple ?secured? video decoding sessions and simultaneous decoding and encoding | |||
H.265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4Kx2K @ 60fps | |||
VP9 Profile-2 up to 4Kx2K@60fps | |||
H.265 HEVC [email protected] up to 4Kx2K@60f | |||
AVS2-P2 Profile up to 4Kx2K@60fps | |||
H.264 AVC [email protected] up to 4Kx2K@30fps | |||
H.264 MVC up to 1080P@60fps | |||
MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496) | |||
WMV/VC-1 SP/MP/AP up to 1080P@60fps | |||
AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps | |||
MPEG-2 MP/HL up to 1080P@60fps (ISO-13818) | |||
MPEG-1 MP/HL up to 1080P@60fps (ISO-11172) | |||
RealVideo 8/9/10 up to 1080P@60fps | |||
Display | HDMI 2.1 output up to 4K@75Hz | ||
HDMI 3D video formats | |||
HDMI HDCP 2.2 | |||
Memory | 4GB (DDR4) | ||
Storage | 64GB(eMMC) | ||
Extended USB Mechanical Hard Disk 2.5/3.5inch 4TB Storage | |||
Extended Storage SD card | |||
Network | 2T2R WIFI IEEE 802.11 a/b/g/n/ac 2.4G 5.8G | ||
LAN 1000M | |||
Bluetooth 4.1 | |||
Interface | USB3.0 | 3* USB Port | |
USB2.0 | 1* USB Port | ||
HDMI | 1*HDMI A Type Port | ||
RJ45 | 1*RJ45 (1000Mbps) | ||
Audio output | 1*Headphone jack,3.5mm | ||
SD Card | 1* SD card Port | ||
DB9 | 1*RS232 port | ||
DC-in | 1*DC in Port | ||
Remote control | Standard Infrared Remote(IR) | ||
Extended 2.4G Remote | |||
LED display | Green LED display | ||
Upgrade OS | 1* Upgrade button | ||
Software OS | Android 9.0 | ||
Adapter | 12V-1.5A 18W Certification Input: 100-240V~50/60Hz , Output: 12V 1.5A |
Work Environment | -10?C--45?C,30%--90% Humidity | ||
Storage Environment | -20?C--60?C,10%--90% Humidity | ||
Accessories | 1*Adapter 12V 1.5A | ||
1*HDMI Cable 80CM | |||
1*Manual | |||
