A95X F2 Netflix and Amazon Prime problem
    Hi
    I request help for a kind of problem with Netflix app and Amazon Prime Video on a A95X F2 4/32Gb.
    First problem is that it's impossible to have any 5.1 sound (works fine with MX Player and Kodi), even with SPDIF outpout or HDMI. Second problem is image quality, look like 720 (and lower) and regulary it's really very low quality, like if there where not enough speed on my connection. I check it with meteor and there is no problem (Ethernet and Wifi).
    Does anybody have same probleme or any solution ? Did i mistake something ? Thanks for help
    Best regards
    seb
    First
      Only Netflix certified box can have upper resolution than 720P,otherwise it can be 720P or lower,nothing wrong with the box's hardware or software.
      It's Netflix that pull the plug off,they need certification.Just like DTS,Dolby,they all need certification fee,quite fat fee...
      No idea about Amazon,guess the similar cause,they are commercial companies,they need profit.
        +1
          Thanks for explain.
            I recently bought a A95X F2 from Geekbuying.com and will never buy from them again..lol...But the WiFi doesn't work and they sent me firmware for a MX10 3328 Rockchip how wonderful.
            The box came with firmware 2019 08 29.....does anyone know if there is firmware that will correct my WiFi problem?
