Mecool KM9 Gearbest model - Stucked on remote
    Hi there,
    I buy a KM9 (no Pro Edition) from Gearbest, the box is working but i notice the LAN/WLAN Bandwidth is cut on half. I connect it to a cable that i know its receiving 180 mbps and it just detect 50.
    So i read somewhere that the rom could be locking it, more research and i found a 9.0 rom for KM9 Pro that works well on this box also.
    I installed it but now it is requesting to sync the remote, i try the standard remote (IR) and it's working but for some reason it's not accepting my input (low sound key + OK).
    Searched again and it seems it requires a Bluetooth remote now.
    I also install in my phone the "Android remote" and it detects the box even through Wifi or Bluetooth. But the symptom is the same as the IR remote.
    Anyone knows..
    A way to skip this step?
    Or a rom that dont have the bandwidth lock?
    Hope you can help me.
