MECOOL K7 Android 9.0 Amlogic S905X2 4GB LPDDR4 64GB EMMC DVB 4K TV BOX
Greeting. I bought a Mecool K7 through aliexpress. I am from Croatia and have the same issues as Bart69. The picture on the DVB-T2 channels freezes frequently. When I switch from DVB-t2 channels to IPTV then I have no sound on those channels. I upgraded the system to OTA update K7-ota-V2.20191015.113941 and reset to factory settings but the problem was not solved
Dear GeekBuying_Rep ,
I have just received my MECOOL K7 (order#5133604) and I have a few problems:
1. It is not rooted. How do I root it?
2. The DTV app is defective. In Network ID scan, the Symbolrate requires has five digits instead of four, so every scan fails.
3. It is limited to 1080p by having wm size set to 1920x1080 and I can't change it to native 4K without root.
Best regards,
Bogdan
Best regards,
Bogdan
Sorry for the issue.
We are checking it and find the solution.
I will post if any updates.Coupons Updated Every Day: https://bit.ly/2RnbHUi
GeekBuying_Rep
After 3 month i repost my problem with K7 without solution or reply from you
It is great product but it have a problem with CCCam (or DVB app?).
With a working c-line the SAT (DVB-S2) channel became de-scrambled but the DTT (DVB-T/T2) channel still remain scrambled.
I have try the same c-line in a KII pro & KIII pro and they working well for all channel (SAT and DTT).
I have compared the settings (via webif) and the settings are the same.
Any update to resolve/fix the issue?
P.s. I have just installed the firmware update K7-ota-V2.20191015.113941
Thx!!
Thx!!
We will check it and get back to you if any updates.Coupons Updated Every Day: https://bit.ly/2RnbHUi
Best regards,
Bogdan
1. The current software of K7 is not rooted. There is not a new version to root it yet.
2. (1) In the Network ID scan, try to enter only the last 4 digits, and then searches.
(2) Change the network type to Any, then enter a center frequency and symbol to search again.
3.Can you sens us a TS stream so that we can test it?
By the way,which country are you located in?Coupons Updated Every Day: https://bit.ly/2RnbHUi
Thx!!
Please kindly send me more info so that we can find a solution.
1.The software version date of KII PRO or KIII PRO you are using.
Then we compare the version of OSCAM to see if there is a difference.
2.The satellite you are using.
The TP's programs that cannot be played.
The name of the satellite and frequency program.
It would better if you can offer us a video so that we can know them clearly.
There are currently 1948 users online. 2 members and 1946 guests.
