Ship from China
Highlight
Intel Braswell Celeron J3160
The Celeron J3160 is manufactured in a 14 nm process based on the Airmont microarchitecture. This chip operates at 1.6 GHz with a turbo mode of up to 2.24 GHz. This SoC incorporates the HD Graphics 400 GPU which has 12 execution units and operates at 320 MHz with up to 700 MHz bursts.
Two Ways to Extend the Storage
The mini PC can use M.2 2280 SSD SATA and TF card to extend the limited storage
LPDDR3 4GB and 64GB eMMC
J36-V mini PC is equipped with 4GB RAM+ 64GB ROM, supporting stable operations and providing you with more space and caches to enjoy your entertainment.
Dual Display
Built-in HDMI port and VGA port, you could display your screen through these two output methods.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
1000M LAN
1000M LAN can improve the net speed and performance to a large extent.
Buy it now.
