TANIX TX9S KODI Amlogic S912 4K HDR TV Box
    TANIX TX9S KODI Amlogic S912 4K HDR TV Box Android 7.1 DDR4 2GB eMMC 8GB HDMI 2.0 WIFI Gigabit LAN Remote Control
    Ship from China
    Highlight
    Amlogic S912
    Amlogic S912 CPU is a high-performance octa-core 64bit chipset, which maximum clock speed of up to 1.5GHz. Apps will run so smoothly in the TANIX TX9S TV box. People can easily enjoy many hot games and APKs with its 3GB DDR3 RAM and 16GB Flash ROM.
    DDR4 2GB RAM + eMMC 8GB
    It uses a DDR4 2GB RAM and an 8GB eMMC 5.0 for better performance, security, and reliability. Supporting SD card to extend the storage up to 32GB.
    HDMI 2.0
    Built-in HDMI 2.0 transmitter including both controller and PHY with HDR, CEC and HDCP 2,2, The HDMI cable will also in the package.
    4K Ultra High Definition
    TX9s with 4K ultra high definition streaming capability that can bring you a best-in-class television experience. Your life will be clearer.
    Gigabit LAN
    Gigabit ethernet has 120Mbps data transfer speed that leading you to a light-speed web-surfing life. Let your life a-step faster than others.
    Check more now.
