X2 PRO Amlogic S905X2 Android 9.0 4K HDR TV BOX
    X2 PRO Amlogic S905X2 Android 9.0 4K HDR TV BOX 4G DDR4/32G eMMC 2.4G+5G WIFI USB3.0 1000Mbps LAN OTA Samba Server
    Ship from China
    Highlight
    Amlogic S905X2
    X2 Pro tv box runs Android 9.0 on Amlogic S905X2, which provides the user with ultra-fast running speed and professional image processing.
    Android TV 9.0 OS
    It is based on the Android TV 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
    OTA (over-the-air) Updates
    When your device gets an update, you will be the first who knows about this. Just stay connected and the system will install it automatically.
    Gamepad Settings
    Brand X2 Pro feature for gamers. Reach greater results in games now, when you can customize your game controller at your own taste.
    Samba Server
    Turns every Brand X2 Pro TV Box in a simple file server. Simple installing and basic security let you share files in your local network very easy.
    Buy it here.
