[HELP] Stuck on rom AtvX logo
    Hello guys,
    I wanted to install AtvX on my S905X box once installed, it's stuck on this screen :
    Even when I try to reset it with the button on the "av port" it won't, the same screen shows up.
    Please help me i'm clueless :'(
    This is my box, it has 2Gb ram and S905X
    Thanks.
    You tick erase flash?
      Are you sure your device is an S905X chipped device? If I had to guess you have an S905W and that is why it didn't install. And if you look at the Amazon page one of the pictures says "S905W"
      Short-the-Pins to get into mask ROM mode and use Amlogic USB Burning Tool with USB.a-to-USB.a cable to recover device to factory stock ROM.
      See forum.atvxperience.com for further tips and tricks to installing atvX.
      Note: Not all S905X or S905W devices are compatible with atvXperience.
        Yes, erase flash is ticked.
          Yeah Ik that, but on the site page and on the specs page, it mentions S905X, I already tried with S905W it didn't install at all, after I poster on their forum, they said the box was S905X and I had to try with the rom, now it's installed it's stuck on that page
            If you have the stock ROM, then install that to recover device in a working state, then can try atvX again with USB Burning Tool and don't check Erase Bootloader,because it may be an issue with incompatible Bootloader. If that doesn't work then your device is probably not compatible with atvXperience.
              The problem is I don't have the stock rom anymore, I had to know that it's clone box :/ of Dolamee D5, I opened it to take pictures if it can help
              (front) (back)
ID:	786068Click image for larger version
