●Main Features: as found
Rapid and Responsive Running
Equipped with the high-performance CPU+GPU Amlogic S912 Octa Core ARM Mali-T820MP3 GPU up to 750MHz, GT-King TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games.
●Great Compatibility
Adapting the Android 7.1 operation system, TX9S is compatible with more software, games, and applications, improving users' experience.
●2GB RAM + 8GB ROM
Allows you to display high-definition video smoothly, and 8GB ROM storage memory supports you to download massive resources from the internet, such as movies, software, and applications.(Support SD Card maximum expansion 128GB)
●Stable and Fast Data Transmission
2.4GHz WiFi and 1000Mbps LAN run internet, streaming and audio perfectly without jerking, which allows you to play 4K@60fps, 3D and H.256 H.264 videos smoothly.
● Operation Temperature:-10 - 40℃
● Storage Temperature:-20 - 50℃
● Humidity environment:5% - 90%( no condensation)
● Remote control powered by 2 x AAA Battery ( not included )
Gearbest
