[ROM] Android 9.0 Alfawise A8
    Hello, this is my first post and I bring you a surprise. Android 9.0 for our devices provided by email support from Alfawise, incredible firmware, very stable and snappy with an all new incredible interface. I also provide the tool to flash the device correctly (Alfawise didnt provide one).
    ANDROID 9.0 DOWNLOAD FOR ALFAWISE A8
    https://mega.nz/#!8Yl1GQLK!yIdU2MXHf...8Up28d_mMTVxaM
    The link contains the ROM and the tool to install the update. To do this, you need a USB A (male) to USB C cable(male) in a modern computer or a USB A (male) to USB A (male) You need something push the reset button inside the AV hole With the power removed we press the reset button and with the Alfawise A8 connected to the PC in the USB port number 4 with the label: USB-4 and we now connect the power cable and start the application provided. Within the flashing application we load the ROM and choose to restore as the option.
    REMEMBER TO DO A BACKUP
    I hope you like it.
    The new interface looks awesome!
    This firmware work on Alfawise A8 Pro ?
      Nice rom. But Remote is not working on MXQ Pro 4k. Also Launcher is from ATV 6 not ATV9
        God bless you Brask!
        I finally have ? working TV BOX. Mine A8 was faulty and was playing videos with lag, even 720p so I did not use it at all.
        I came across this post by accident, and decided to give it a try!
        Now playback is still not perfect, but it is bearable
        Btw, I contacted Gearbest support and the answer was there is no Android 9 rom...
        Regards!
          I hope you like it.
          This firmware work on mx9?
            It is for all Alfawise A8 devices, other brands and models I don´t think it will work.
              Regards!
              Thanks!
              I was provided the ROM from Alfawise support via email, I asked them for a new ROM and they provided this one.
              Anyone wanting to customize a LineageOS for our devices?
                Would this ROM work on a 1gb RAM device? I have the MXQ-4K version (not the Pro version which has 2 gb RAM). Don't want to brick it so if someone knows, please let me know.
                  As I have commented before, it is for Alfawise A8, all other devices I have no idea, I risked mine for the rest, did a backup first, do the same and make your contribution to the community. Thank you.
                    Hi this is my first post. I installed this rom on a 4k mxq pro, 1gb ram and 8gb rom. Everything works fine except the remote only works power. I tried to joke a bit with the .kl files but nothing to do. Anyone know a method how to do it? Thanks and sorry for my bad english.
                      Hi. Its my first post....
                      So, i`m unable to install new ROM. Right after "Reset Device Start" an error occurs "Download Firmware Fail".
                      when i try with original ROM, everything is fine.
                      Any guesses?
                      Thanks!
                        Did you try?
                        Does anyone know if it's working on Alfawise A8 pro 5G?
                          Any guesses?
                          Thanks!
                          Have you used the provided tools to do so? What OS? Maybe you can try again?
                            Originally posted by gary_t View Post
                            Did you try?
                            Make a backup of your current firmware and try
                              Looks like I will give a try without backup. After little experimenting, I installed SuperSu (Android 8) and after restarting, it got stuck into bootloop. Now rather than resetting, I will install the new ROM. Let's hope everything works!
