H96 MAX RK3318 Android 9.0 [Brick]
    Hi everyone,
    I have this device H96 MAX+ RK3318 Android 9.0 4GB 64GB TV-BOX, my problems begins when I tried to upgrade new firmware from this page "https://www.h96tvbox.com/content/6-Firmware-upgrade", I try to update just because I can usemy VPN program, the box reply alway i wrote wrong user o pwd but wasn't true.
    I Update but always the same problems, after several unsuccessful experiments with another firmware, but I do an erroe and I flash a FW for 3218.
    Then I've got a brick
    The device does not turn on. The red light is constantly on, it does not react to the reset. It is not power on with power adapter and with computer connected USB cable (reset hold).
    Computer doesn't see my TV-BOX because of it powered of can't wake up.
    What can I do for UNBRICK that?
    Some pictures of the box.
      i have same problem on my 2/16gb. only red light on and laptop dont recognize box. bricked because i updated wrong firmware (RK3328-BOX_7.1.2_20180824.1737_H96MAX).
        Well, i got the same problem. But the device just stoped working by itself, i didn't do anything.
        There's only red ligh and no signs of life there
        YouCut 20200116 172056583 - YouTube
        https://m.youtube.com/watch?_lang=pl...&v=OpIuxv1RoNA
        Any suggestions?
          I have the same problem.
          Please help mi to find pins to short.Click image for larger version
            Here are the pins. Are You Polish?
              Thank you. I will try that. I am Czech.
                I have tried short pin but it says "test device fails"
                https://youtu.be/m425mh-z6w8
                Please help what to do now.
                  1. Try other usb ports in your pc/laptop
                  2. Check another usb/usb cable
                  2. Try another software
                  https://www.google.com/amp/s/chinaga...v2-38.html/amp
                    I have tried all of that, but still "Test device fail"
                      Well, You may try another PC.
                      i'm not an expert but there is a chance that Your box hardware is dead.
                        Can u share exact pins to short and process after short the pins?
                          Take pictures (good quality) of both side of your motherboard.
                            i tried but nothing worked , these two orange dots should get short ?
