New Stock Firmware and GT King Pro 906P0
Originally posted by trebor View PostThere has been a fix but as always, please advise:
https://beelink-my.sharepoint.com/:f...PHByA?e=j431uu
Repair:
1. Optimize the system
2. Join Miracast (Android phone can cast screen to the box)
3. The version number is 906P0
4. Add sd card brush function
OTA will be pushed for previous version
does not work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have this version, updated via OTA, but It makes my WiFi and BT unusable. I can't see any AC networks and also N networks with 40MHz channel width and many others I'm unable to connect. If I successfully connect to some AP (some G, N sites with 20MHz channel width and on specific channels) so I've got very poor speedsDo you have anybody the same issues? I hope that they will fix that soon. Also I hope that they build x64 rom.
I have a beelink Gt King SN: 95X2 which was bricked thanks to this?? http://www.bee-link.com/forum.ph ... ge=1&authorid=1 I managed to bring it back to life. Then I start from the original firmware of my GTKing_901K0_20190509 box and then via OTA or manual I get to 905PO but at the next 906PO it hangs on the Beelink Logo. The same is true even if I use USB_Burning_Tool with the 906PO firmware stops on the Beelink Logo I can't understand why would anyone help me in this regard? Thanks !!
There are currently 4246 users online. 0 members and 4246 guests.
