I'm using MXQ-4K esp8089 box with firmware by shaman4ig (Android 7.1.2 kernel 3.10.104)
He has built 2 versions:
- MXQ-4K-7.1.2-esp8089-20180928-shaman4ikMOD_1.1.rar
- MXQ-4K-7.1.2-8189fs-20180928-shaman4ikMOD-V2.3.rar
I'm using V1.1 (wifi esp8089) but the biggest problem is the time after exiting sleep mode is not synchronized. He has fixed it in V2.3 but not for esp8089.
I have tried V2.3 for my box but wifi not work. Tested "insmod" shown: unknown symbol.
I found that the different between both FW is the kernel. The kernel of V2.3 doesn't have ESP8089 inside. If I extract kernel.img from V2.3 and apply to V1.1, time is synchronized but no wifi, if use kernel from V1.1 on FW2.3 then wifi is ok but time not sync.
Could you guy please help me fix my problem: time on V1.1 or wifi on V2.3 for ESP8089?
Thanks.
