HM8 android box breakdown with red lamp
    i have two devices the same model HM8 golden one, are not working anymore, just red lamp not even booting, not responding to anything, can't enter to recovery mood to rest it.
    1- when i connect it via usb with laptop to flash the firmware by USB_Burning_Tool
    it stops @7 %, I tried all possible installations steps. between normal erace and forcing etc , it give me same resultand stop @7%
    Name of firmwares that i used in all my tries \
    HM8-ota-20170401.115942.V0923
    ,, HM8-MHC19J-20170401.115942.V0923 ..
    KM5-MHC19J-20161125.092239.V0923 ..
    All failed.
    2- I tried to install it by using the SD card using the burning tool Amlogic_SDcardMaker_BootcardMaker_burnBootCard_v1. 0.1 and install below files on SD card
    it was a glory to see the green lamp again , android screen installation which freez after awhile, device entered in recovery mode appear for me alist but failed every thing, just i have recovery screen as appear in the shots,
    so i'm still at same status since this time, don't know what to do anymore or what to do further.
    how to recover my device, its looking im so near but im really so far. if i removed the sd card. it's red lamp. when i put sd card, i see only recovery mode options
    which refuses to install the Zip file.
    factory_update_param.aml
    HM8-ota-20170401.115942.V0923.zip
    recovery
    thanks for help or any previouse experience
    Click image for larger version  Name:	5d0386cf-5d9f-447c-b614-9ff979155596.jpg Views:	0 Size:	143.4 KB ID:	786353
    Click image for larger version  Name:	64c29e3b-d543-4056-a249-9ab56640cadb.jpg Views:	0 Size:	116.4 KB ID:	786354
    Click image for larger version  Name:	35229fde-40ac-4073-8a79-e997a7cbddc1.jpg Views:	0 Size:	111.3 KB ID:	786355
    Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
    the log file while failing burning
    موقع المعلومات العالمي
      plk
        Originally posted by mody_bodey View Post
        https://pastebin.com/7X56P7mQ
        You are connecting to usb 3.0 .It must be connected to usb 2.0 .That is , it writes low power.
