Turewell T9 RK3318 + Goobay 58967 Audio Extractor HDMI/7.1= only stereo sound, any suggestion?
    hi to all
    for a testing purpose (for a furher work) i need to test 7.1 sound from this box:
    at now i dont have a surround amplifier with hdmi or optical inputs so i have bought this
    an hdmi to analog exctrator.
    with my windows pc it works fine and the audio signal is splitted to the correct canal, but with the tv box only the stereo canal works (FL\FR):
    i have tried with many different settings (enabling hdmi passthrough on vlc, kdplayer and from android tv side menu settings) without results...
    any suggestions?
    maybe is an issue with the exctractor? i have to try with a true amplifier?
    any helps is apreciated
    Marco
    That device only supports stereo sound since it has broken firmware that will never be fixed.
    So nothing you can do except buy a better device next time.
      hi
      thanks for quick the response!
      i've also tried with this box with the same results: Bqeel TV Box Android 9.0 HK1 MAX / CPU RK3328
      do you have a tested device to recommend me?
      or a working firmware?
        Originally posted by AltCtrlDroid View Post
        hi to all
        any suggestions?
        Marco
        Hi ,
        are you sure your Box supports it , if , for sure the buggy Software ,
        greetings / gefattern
          Hi ,
          once more , please no double Threads , okay ,
            ::edit::
            i can confirm is a firmware problem of T9 android box: only stereo suond
            with the HK1 box and MXPlayer audio files are launched smooth in all 7.1 channels, now i can go ahead with my work...
            thanks for the support
            for the double thread : where is the remove post button?! i've accidentally written in the wrong section
              Hi ,
              +1
