Beelink GT1 Mini 2 updated firmware, Oct. 2019
    Beelink has just posted the latest firmware for their GT1Mini 2 that uses the Amlogic S905X3 SoC. This firmware solves several of the existing issues, specifically utilizing all four cores.
    Specs of this tiny Android box.
    Amlogic S905X3
    Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an "advanced application processor designed for hybrid OTT/ IP Set-Top Box (STB) and high-end media box applications. The Cortex-A55 cores deliver up to twice the performance compared to Cortex-A53 in memory benchmarks, and a more typical 20 to 30% performance improvement for common tasks at the same frequency.
    Android 9.0 OS
    It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
    Voice Remote Control
    Just speak into the remote control and GT1 MINI-2 TV Box will search for what you want.
    2.4G/5G Dual Band WiFi
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    This box is rooted and has an UNlocked bootloader. This gives it the ability to dual boot other operating systems.....
ID:	786676Click image for larger version
Name:	Unlocked bootloader.png
ID:	786677Click image for larger version
    This box supports Google Widevine Level 1 with HDCP 2.2
    Antutu Benchmark 80590
Name:	Antutu bench mark.png
    Aid64 information
ID:	786683Click image for larger version
ID:	786685Click image for larger version
    Aid64 codecs, including VC-1 video codec.
Name:	Aid64 5 VC-1 codec.png
    GHz Wifi band is fantastic, however the 2.4GHz, like most of these boxes, suffer from inadequate reception.
ID:	786688Click image for larger version
Name:	2.4GHz WiFi .png
    Overall, this is a very impressive little box. More testing to follow........
    One glaring omission from this firmware, the "Voice" is killed, same as the new Beelink King Pro firmware......
    Good to see it up and running and all 4 cores excellent
      The latest release is now posted: GT1mini-2_v202P0.img
        Is it still running a 32bit kernel ?. With 4GB memory it is better to run 64bit kernel even if user space is 32bit ARM V7 ABI.
          Is it is still running 32 bit zygote. Kernel could be 64 bit but android zygote is definitely 32 bit as reveal by Aida64.
            [QUOTE=Magendanz;n788946]The latest release is now posted: GT1mini-2_v202P0.img[/QUOTE
            hey all sorry in advance
            How do you update if you wouldn't mind helping me ?
              [QUOTE=Willthare24;n792240]
                The newest ver.. is v203P0.img and can be found here: http://www.bee-link.com/forum.php/fo...read&tid=63479
                  Thank you for that information.
                    GT1mini-2_v204P0.img https://yadi.sk/d/EZ4OFixJ2My3UA
                      Originally posted by Vasilii View Post
                      Thanks for the heads up........
