s912_atvXperience_v2FF Fix Bluetooth Add Twrp
Okay firmware has been edit Bluetooth is fix I I added twrp. Took file front firmware v2F just Bluetooth files and took 2 file fron xbin and 2 file fron bin and less than 15 minutes Bluetooth was working. On Twrp took from Firmware 4.7 poison recovery.img and recovery file . I did the test on a Minix u9h everything working
Thanks Antonio. My cousin tried to use this firmware for his Minix U9-H.
USB ports aren't working for him. (using NEO A3). Bootanimation distorted for few sec too.
Anyone else has the same issue on MINIX U9-H?
Otherwise, it seems to be a nice firmware if don't mind using OTG port to connect USB device.
Thank you so much Antonio for all the efforts.
Hello
I need a ROM which works Amazon prime and other OTT apps with ATV Experience
Please suggest me which one is works better for MECOOL M8S PRO L DDR3 LB Model.
i have tried many ROM that is installed successfully but wifi and bluetooth is not working,
only stock and nexus rom works but no OTT Apps
There are currently 2252 users online. 1 members and 2251 guests.
