T95Q Android TV box behaving badly ( garbage display )
    Hello
    my T95q been working ok in the last few months but once in a while i've been noticing this screen.
    Now i can't use my box and its keep producing this screen as i was watching youtube or kodi.
    all my SOURCE from hdmi ouput TV / monitor give off same result so its not the source its from the box.
    i also have a fan on the bottom whenever using the box.
    box is not warm and also the 1st few minutes its doing this screen too.
    attached is what the screen looks like.
    appreciate all feedback/help.
    thanks,
    Just to verify that it is not the box, and if you have a spare micro SD card, try installing CoreELEC. If that works, then you know the hardware on your box is okay.
      okg.?? ??
        right now the devide is intermittent...so i'm waiting for backup using TWRP then i will try either update to v9 os or CoreELEC.?  that way i can go back incase something happen correct??  seem to me TWRP isn't easy to do.?  still googling
