[ROM] Beelink GT1-Mini ALVATECH Standard Android (9.0 Pie) S905X2
Can you kindly help me how to install magisk. I have tried to install via TWRP it does not show. Also now power icon says does not have access to root permission and shutdown menu is not showing
Sent from my VOG-L29 using Tapatalk
I hope to soon release some links and information on this topic. I will be putting this info on the 2nd post of this thread under the Extra Tips Section. In the meantime you can use the status bar at the bottom and use the power button to turn off the box.
Thank you,
AlvatechLast edited by ALVATECH; 28 January 2020, 22:33.
Hi Alvatech,
Thanks for this great ROM. It works nicely on my X96Max 4/64. I flashed it with Sdcard method, very fast.
Just, a minor problem, now i lose the functionality of the remote controller.
I understand that at earlier version, I can solve this by tweaking remote.conf file. Can we do something similar to solve this? Where to locate this file?
It will be very nice if we can make the remote working, but if not, I can live with that since I use mouse all time.
Rgds,
Javen
Rgds,
Javen
You're welcome. The files you're looking for would be in the original firmware for your box. But more than likely the files would be in vendor/etc directory. I don't own an X96Max box so this is something you would need to troubleshoot with your own remote.
Thank you,
Alvatech
Originally posted by lomak View PostHello! You can make a separate fix voice support for other remotes too. Example G30S remote. For TV Box Beelinl GT1 Mini rev. SN:B905 or SN:B95X, stock firmware.
Thank you,
Alvatech
Hi Alvatech,
Previously i wrote the message below and put your 8.1 oreo rom Info my box but it did not help. I want to put this rom but i can't download it from mega.nz website because of the limit. And for some reason, i can not register to the web site. Can i download it from somewhere else?
i have beelink gtmini-a SN:B95X version, it was working fine until 2 weeks ago. It stopped connecting to wifi, i have rebooted both my wifi router and tv box it does not solve the problem. it says the wi-fi router does not accept the connection but i tried other routers it always says the same thing.
Now, i am thinking to update the firmware to fix this problem. Do you have any suggestion for me? Do this rom solve my problem?
Best regards,
I tried some ROMs but your's is the best.
But when I press MIC button on remote I see only GoogleAssistant.
Then I installed anther ROM and I copy com.google.android.katniss to your ROM in system/priv-app.
So when I press MIC button on remote I see 2 apps.
Google-katniss can search your reqest in many apps.
Thanks Alvatech for your hard work.
I installed your ROM, testing for a day, all loooks fine.
my problem is I can see videos are playing like in a low resolution (Netflix, IPTVs, etc), in youtube (the app coming with) I can select highest resolution, it plays but appears still not good resolution.
previous rom was OK (sasvlad), I see a limited options in TV Settings...
any clue? thanks in advance
Thank you,
Alvatech
Best regards,
I don't have much cloud space. I've used up a lot of my g-drive and that's why I added mega, but I don't have any issues downloading any ROM's from there, so not sure why you can't. Also to me it sound like you have a hardware issue not a software issue. But re-flashing may help but it's not a guarantee. You could always flash the stock ROM from Beelink and see if it helps any. If you continue to have issues then more than likely your box is faulty.
Thank you,
Alvatech
Hello,
Thanks for the perfect work.
I use NETFLIX and it works well. I wanted to try HBO GO but it doesn't work. I installed the application from Gplay and after running the application will report that I am not connected to the Internet, please restart the connection. I use a wired connection not wifi. Everything else works as my internet connection is fine. Is there any way to solve it or where the error is.
Thank you
Thank you
Thank you,
Alvatech
There are currently 12637 users online. 2 members and 12635 guests.
