Thanks In advance
Driver Problem
Driver Problem
So I tried to install the Rockusb drivers (v.3.5) on my T-R42 BOX but i get Error code 10 "The device cannot start".Please help me I don`t know what to do I tried restarting the computer, reinstalling the drivers (tried that at least 4 times),I`m out of ideas what should I do please help me.
Thanks In advanceTags: None
No usb needed maybe?
Originally posted by dinaxe View PostSo I tried to install the Rockusb drivers (v.3.5) on my T-R42 BOX but i get Error code 10 "The device cannot start".Please help me I don`t know what to do I tried restarting the computer, reinstalling the drivers (tried that at least 4 times),I`m out of ideas what should I do please help me.
Thanks In advance
Right done research it is the same as my box and only difference is yours uses bluetooth apposed to mine without it so yes the drivers are prebuilt into the device and not needed to be downloaded seperately just enable connect to pc option with adb debugging in developer options disabled to get into the folder structure (root) of the device and to flash the thing just follow
How to update firmware on K-R42 quad core tv box?
guide i used at geekbuying site it has pictures and instructions step by step and even points out where to get firmware etc,although i take it this site also has a similar guide somewhere i am guessing it does any way.What is the world if you don't explore?
Originally posted by PHYSC View PostI assume it is similar to my k-r42 software/hardware wise if so i had the same issue trying to add drivers,but if you are trying this so that you can flash it then they (the drivers) are maybe not required as with my box in order to flash in adb mode you simply plug in micro usb to pc then remove the power lead and then hold the restore button underneath and plug in the power cable again whilst your holding in the restore button do this until you hear the usb detected noise ("didung" sound)on the pc,then release the restore button underneath and you are in adb mode ready to use the RKBatchTool--1.7.exe for flashing a stock or a custom firmware you choose the .img file in the firmware folder to flash it and choose restore to make it flash the file to the box,after i did a flash of hmw custom firmware on my box i found that it i had adb mode enabled in the developer options automaticaly and it could not detected the tv box as a accessible usb drive and therefore i just left it (usb debugging) disabled,also there is a 'connect to pc' option needs enabling on my box to make the pc detect it via usb.Hope this might shed some light on the situation if it is related at all?
guide i used at geekbuying site it has pictures and instructions step by step and even points out where to get firmware etc,although i take it this site also has a similar guide somewhere i am guessing it does any way.But now I have another problem I installed Lewy`s firmware,after that I tried to flash wasser`s 720p kernel for the T-R42 but i get a error:"Load Firmware Failed!".Am I suppose to flash it via CWM ?
well done
Originally posted by dinaxe View PostI managed to flash the kernels I was using RK Batch tool instead of Finless Flash ToolsWhat is the world if you don't explore?
There are currently 2079 users online. 1 members and 2078 guests.
