UGOOS AM6 Pro Android 9.0 TV Box 4GB + 32gb Dual WiFi Gig Lan BT5
    Had to happen and it has the 4/32 gb version of the Ugoos AM6
    UGOOS AM6 Pro Amlogic S922X 4GB LPDDR4 32GB, Dual WiFi Gig LAN USB3.0 BT5.0
    Main Features
    ● Android 9.0 operation system
    ● Amlogic S922X CPU, Quad core, ARM Cortex-A73, 1.7GHz + Dual core ARM Cortex A53 1.8GHz
    ● ARM Mali-G52 MP6 (6ppc) GPU
    ● 4GB LPDDR4 RAM + 32GB EMMC ROM
    ● 2.4GHz + 5GHz dual band WiFi, IEEE 802.11 a / b / g / n / ac and 2x2 MIMO
    ● 1000M Ethernet Integrated IEEE 802.3 10/100 / 1000M Ethernet MAC with RGMII
    ● Support Bluetooth 5.0
    ● Support 4K ultra HD image display
    ● Support H.265 decoding
    Gearbest
    Looks really good
      Yer should be an Excellent Unit for those that need 4/32
      • gefattern
        gefattern commented
        Editing a comment
        Hi Trebor , the Header says AM6 not Pro , same with first title in Post 1 , greetings / gefattern
      Great Box. I can recommend it.
        Hey D, what are you seeing as baseline Ram used, post boot, but prior to opening apps and programs?
        ​​​​​​... And what are your Ram norms when working with multiple functions active.
        I'm trying to compare to my 2/16 model, and contemplating an upgrade exchange. cuz mine constantly runs 75-90 percent load, while restricting many/most active apps. hmm?
          hey all!
          If you want one?
          You better pull this coupon trigger....
          cuz retail across the Ugoos resellers is now north of $150 usd.
          My 4/32 Pro is arriving shortly. I just had to Ram it Home. ;-y
            AM6 Pro seems to have a few interesting features.
            The only downside should be that it runs @1.8Ghz and the original AM6 is @2.2. Maybe the next update will speed up de SoC back to 2.2Ghz.
              kpk1 it's no downside. Neither is the fact ugoos opted for a huge finned heat sink vs the active cooling originally planned.
              Very few delivered units ran at 2+ ghz, very few.
              As a owner, I believe they Know What They Are Doing... far better than most. Though you won't be able to judge for yourself unless...?
              Or, you can stay with the "also rans" ;~}
