External touch screen to Minix Neo X5
    Need help:
    I can't get an external monitor (Acer T232HL bmidz) to work (meaning touch functionality)
    I'm now running neo_x5_finless_12b_rom (tried different stock roms)
    lsusb list the monitor as 2149:2306 and I have tried to do a Vendor_2149_Product_2306.idc file
    From ADB logcat:
    --------- beginning of /dev/log/system
    W/Vold ( 82): subsystem found in netlink event
    D/Vold ( 82): usb, 1
    D/Vold ( 82): == current usb device: 05E3/0610 ===
    D/Vold ( 82): == current usb device: 2149/2306 ===
    I/EventHub( 266): New device: id=4, fd=209, path='/dev/input/event3', name='Advanced Silicon S.A CoolTouch(TM) System', classes=0x4, configuration='/system/usr/idc/Vendor_2149_Product_2306.idc',
    keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=false, usingClockIoctl=false I/InputReader( 266): Device reconfigured: id=4, name='Advanced Silicon S.A CoolTouch(TM) System', surface size is now 1280x720, mode is 1 I/InputReader( 266): Device added: id=4, name='Advanced Silicon S.A
    CoolTouch(TM) System', sources=0x00001002
    Anyone?
    Following up on your progress
    Originally posted by jonce69 View Post
    Need help:
    From ADB logcat:
    Anyone?
    I recently purchased 2 Dell S2240T monitors (hex 2149:2122), which also use the Advanced Silicon, S.A. CoolTouch system, and I am now to the point where I have exhausted simple config options to make it work correctly -- so, I am wondering if you have had any luck, yet?
      No, no luck
        Anyone that have succeded to get any touch screen to work with minix? How is it sopposed to work, pic/sound through HDMI and touch via USB?
          No newer informations about this problem here?
          Do you think my english ist bad??? Did you forget, i am from germany! Sorry!
