Is there any firmware from any other more fluid box rk3399 that works on h96 max???
    No firmware is fluid on my h96, since I bought it, could never use, always stops working or does not turn on (already tried all possible firmware)
    Is there any firmware from another rk3399 box that is fluid that I can test on H96 Max rk3399 ???
    Hi ,
    did you tried Superceleron Rom ???
    greetings / gefattern
      Hi ,
      Yes,
      all existing for h96 max
        Originally posted by RicardoBR View Post
        Yes,?
        Hi ,
        not sure but i read somewhere that the N6 Rom shall work , but to be sure you only can test , that is your Risk , maybe better to buy new Shield then always have bad China FW luck ,
        turns not on , enough Power ???
        good luck / gefattern
          it works, but it takes a long time to start, hours, and when it starts, it crashes
            Hi ,
            Magicsee N6???
              Magicsee N6???
              Hi ,
              yes , but not sure , better to read the Threads , think it was in X99 or your Box Thread ,
              i was bricked too yesterday , was able to restore with SDFlash , so ,
              what about something new ???
                I tried, it didn't work
                  Hi ,
                  but not bricked hopefully , there is a mixed Rom from Y8 and a Dev. Board or RK3399 somewhere here , maybe this , but it is in parts , maybe Time to buy a Shield and leave this , waste of Time looking for working Roms , behind us ,
                    Hi ,
                    some News ??? , i am really frustrate because of this bad SU support ,
                    stupid chinese bad Rom Makers ,
                      i have my h96 max x99 n6 firmware running 20190604_N6MAX_update and t9_rk3399_d32_ap6255_x99_20190424_r1 but they all have the same problems
                        Hi ,
                        so N6 Roms working on H96max , do you have a Link of the 2019 X99 Rom ??? , what are the Problems on your Box ???
                          http://www.magicsees.com/help.aspx n6 x99 rom https://yadi.sk/d/xV1K6mtI3kfWmA n6 usb does not work in some app s problem was not robust x99 my problem google play old does not work usb3 does not work but the whole app works i need the image is nice too
                            There is root in the firmware 20190424 x99 Do not forget to sew on the USB with a FactoryTool v1.45e computer only
                              Hi ,
                              sorry , what shall i not forget ??? my X99 must be flashed over USB C , i used last AT2.59 worked well ,
