[ROM] POISON TV GT1_MINI2
    Originally posted by dangchui View Post
    hello ANYONE he test this rom with NETFLIX ATV version 3..2.2 VERSION but with do an astuce similar with patch yablio same at this :
    WITH THIS VERSION : https://drive.google.com/file/d/1RGQ...AMcpSjk-p/view
    and patch yablio :https://drive.google.com/file/d/1Wek...7JKaiz5Nq/view
    be careful only run patch yablio who run netflix atv
    thanks for verify this and test is ok on KM9 PRO google certified
    and beelink GT1 MINI 2 is OK HDCP 2.2
    tested with stock firmware, got error code.
      hello you say with stock firmware but you say original firmware android classic or with firmware ANDROID TV POISON ATV ????
        Stock firmware means firmware from Beelink, which is a non-ATV rom.
          AH ok MCTIEW Thats normal then this astuce don 't work because that s for ANDROID TV only
            I was waiting for Minixfreak to upload his newest version of the ATV port. I will test again when I am running the ATV port...........
            Edit: I installed Minixfreak's ATV port again, but those two files will NOT install, so can't be tested.
              Won't install or an install error ? Need to grant the file browser application to install from unknown source ....from somewhere in the settings.
                No, it won't install.... That is a problem with this port, I can't install any external app. I am not trying to install from the browser, but from a networked or local drive....
                  Permission to install from unknown source has to be granted on per app basis. The app here refers to the file manager app, not the web browser.
                    Permission to install from unknown source has to be granted on per app basis. The app here refers to the file manager app, not the web browser.?
                    I understand, but for whatever reason, this will NOT install external apps. I tried to install aptoide when I previously had the port installed, but same thing.......
                    Out of all my devices and ports, this is the first time I have run across this issue..........
                      Link broken dude, can u upload file again pls?
                        Must be retracted by developer.
                          im remaking all my firmwares as my hard drive crashed and lost everything have to start from the begining again be patient everyone
                            Wow, that is awful, sorry to hear that........
                              duplicate
                                The stock firmware users can try the MANUAL ESN feature in Kodi Netflix plugin.
