Magicsee N5 Plus Android 9.0 Amlogic S905X3 4GB RAM 64GB Dual-band WiFi USB 3.0 SSD Hard Drive Expansion
    Magicsee N5 Plus Android 9.0 TV Box 8K HDR Ultra-HD Video
    Amlogic S905X3 4GB RAM 64GB ROM Dual-band WiFi USB 3.0 4TB HDD / SSD Hard Drive Expansion
    Features as Found:
    Make Your Home Become A Cinema
    Magicsee N5 Plus TV Box uses the latest Amlogic S905X3 ( quad-core ARM Cortex-A55 ), the latest general-purpose SoC for Amlogic's current home audio and video market, and the only consumer-ready chip that supports 8K video playback. The S905X3 uses a 64-bit quad-core A55 processor and a G31 graphics processor. It supports the HDMI 2.1 standard and supports 8K video hard decoding and output. This 8K streaming media player is equipped with an open Android 9.0 system, which is one of the best choices for your home viewing, video playback and games.
    ●Amlogic S905X3 Quad-core CPU + ARM G31 MP2 GPU
    Comes with the high-performance CPU + GPU, making the N5 Plus TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games, which improve the running speed and enhances the image processing capability.
    ● Support 2.5 inch 4TB HDD / SSD Hard Drive Interface
    Whether you are home, work, life, games and other storage needs, easily meet your storage needs. (Not included in the package)
    ● 4GB RAM + 64GB ROM
    4GB RAM + 64GB ROM storage memory allows you to display HD video smoothly and download massive resources from the Internet, it is large enough to store large numbers of movies and Applications and browse the web, etc.
    ● HEVC H.264 VP9 AVS2-P2
    Various video decoding can save more bandwidth resources, let you watch the 8K movie smoothly.
    ● 8K UHD Resolution
    Support multi-video decoder up to 8K 24fps, 4K x 2K @ 60fps + 1 x 1080P @ 60fps, which provides much more detailed and better-looking image.
    ● USB 3.0
    The transfer speed is theoretically 10 times faster than USB2.0. You can quickly transfer movies, images and other resources from USB drives or mobile devices to the TV box for playing.
    ●Android 9.0 OS
    Adapted Android 9.0 operation system for strong compatibility, it is compatible with more software, games, and applications to improve user experience.
    ● Root Swtich
    Rooted or not rooted, N5 Plus can enjoy the best of both worlds. There is manual control to switch the root access on or off as you like.
    ● Hardware Monitor
    CPU, temperature, network, load RAM real-time performance, each one is under control.
    Gearbest
    $59.99 Flash sale
    2018.11.10 15:00 00:00 2018: 12.11(Beijing Time)
    Shhh, dont tell everybody, you may miss out
    i can't find any review .where i can find more for that box ?
      Yes do we know where to see a good review?  I've searched the net but i didn't find anything!!
        hi do we know if this model and n5 max come with ddr4 or ddr3?!
          Hi there. Here the review. There is DDR3 in this box.
            Magicsee N5 Plus Android 9.0 TV Box/4+64G
            coupon:GBCNN5PLUS $56.99 300pcs
            Gearbest <<< click
              It seems that they send the "good stuff" only to reviewers =)
              I got a _2019-10-10_ board with Hynix NAND, another batch of DDR3 RAM and a even smaller heatsink* (~2.5CMx2.5CM).
              Also that extra unpopulated connector is missing on this one.
ID:	791903Click image for larger version
                New firmware: http://www.magicsees.com/help.aspx. Update possible only via USB Burning Tool.
                  Thanks, for the info.
                  Is there any compatible atv rom?
                    Hoping there a 1000m lan equivalent.
                    100m is too limited.
                    And the chassis is better for aluminum.
                      Unfortunatelly 100mbps LAN and plastic chasiss here...
                        The firmware on this box is awful! Very poor QA on this.
                        * Cannot drop down staus bar, impossible to see/clear notifications.
                        * Ethernet cable shown as not connected after a reboot.
                        * Occasional clicking/popping audio.
                        * ‘#’ character always visible at top of screen when playing fullscreen video in root mode.
                        * Q key doesn’t work when using hardware keyboard and cannot hide onscreen keyboard when using hardware keyboard.
                        * Some sites won’t play video (chrome or firefox) eg oomovie.net.
                        * No access to normal system settings menu.
                        * Cannot use many alternative launchers because you cannot drag icons around (apex, evie, microsoft, nova). Lawnchair and openlauncher work.
                        * If you install an internal drive, you will need to format it on a PC beforehand or it will not be recognised and there is no facility to format/partition the UI.
                        * Zero support (emailed magicsee twice with no reply after 3 months since first email).
                        The firmware update (20191101) appeared to fix browser and ethernet connection issues as well as hiding onsrceen keyboard when hardware keyboard is plugged in.
                        Some workarounds:
                        added lines to /vendor/bin/preinstall.sh
                        # Clear notifications every minute
                        nohup sh -c "while [ : ]; do service call notification 1; sleep 1m; done &"
                        add line to /vendor/usr/keylayout/Generic.kl
                        key 16 Q
                        comment out line in /vendor/bin/killsudaemon.sh
                        #ps -A|grep daemonsu|awk '{print "kill -9 " $2]'|sh
                        comment out everything in /system/bin/install-recovery.sh
                        and add line
                        /system/xbin/daemonsu --auto-daemon &
                        To access normal settings, press volume up or down then click on the cog icon then click back arrow.
                        All in all I can't wait to get armbian running on this box!
                          A95x max is 1000m lan.
                            Yeah,but A95X max sports S905x2.
                            Really hoping there is such a model based on S905x3 with 3.5inch HDD housing.
                              If you want to use a 3.5 inch drive, the only boxes I know of are made by zidoo. They aren't cheap but you get what you pay for (dualboot, updates, hdmi in, support). The Z10 takes a single 3.5in up to 12Tb. These boxes don't use amlogic though, instead you get realtek SoC.
