Help please. Thanks
Help with MK809III Bricked
Hi. I need help to unbrick my MK809III. I was trying to update the ROM on RockChip Batch Tool 1.7, but could not. Then the light turned Blue on the app. Need to unbrick please. I thought its an MK809III but when I opened it, I am not really sure if its an MK809III. Dont know where to short this thing. It’s written RK29_809_V1. I need the proper ROM as well as I tried an RK3188 rom and that’s when it got bricked.
Help please. ThanksYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
Originally posted by irshad86 View PostHi. I need help to unbrick my MK809III. I was trying to update the ROM on RockChip Batch Tool 1.7, but could not. Then the light turned Blue on the app. Need to unbrick please. I thought its an MK809III but when I opened it, I am not really sure if its an MK809III. Dont know where to short this thing. It’s written RK29_809_V1. I need the proper ROM as well as I tried an RK3188 rom and that’s when it got bricked.
Help please. Thanks
think it is a RK3229 , try the Pins 7/8 ,
use latest Drivers & AndroidTool 2.35 or above ... ,
good luck / gefattern
Originally posted by irshad86 View PostHi, thanks for the reply. Much appreciated. I dont even know where the pins 7/8 are found. Could you show me where the pins are?
first quote the last Post so anybody you answer can see it , behind USB Port , first Picture , not sure because you can not see the typic marks , but if you start on the USB Port side and test , you will find for sure the Pins on one of the solder Rows ,
Hi ,
Hello
Thanks for the tips. So I followed the steps, got the device connected, loaded the rom. All was successful. But when I connected the device to the TV, there was no signal. I tried several times, no result. Did the same with RockChip Batch as well. Success message (green) but no signal/sign of booting when connected to TV.
Not really sure what I missed there. Any idea please?
Irshad
gefattern
Hello
Irshad
what TV do you use ??? 1080P / 4K , please try another older TV with 720P / 1080P , maybe it is bricked , then it is better to buy a new Box ,
greetings / gefattern
There are currently 2384 users online. 0 members and 2384 guests.
