I have no use at all for any Google functions or apps (like Play Store, Calendar, Contacts etc.) on my Android TV box which is a A95X Plus (S905Y2).
I tried disabling all the Google-related apps and that worked fine. But then I went to delete them from the system with Root file browser and that created a broken TV box.
How do I safely remove all the Google related apps and all unecessary apps?
For example, I am not able to find where the Play Store is installed to?
Thank you!
