GT-King Pro VolksWare by Sasvlad v.2.0 (Standard Android 9.0 Pie)
    GT-King Pro VolksWare by Sasvlad v.2.0 with TWRP English and Russian Version
    based on stock 906P0
    Hi, I present to you my first firmware for this box.
    The firmware is made in 2 versions: Russian and English localization.
    Many thks to Beelink for sending me the machine.
    Click image for larger version  Name:	home.png Views:	0 Size:	602.7 KB ID:	788321
    Click image for larger version  Name:	Search.png Views:	0 Size:	870.5 KB ID:	788322
    Click image for larger version  Name:	katniss.png Views:	0 Size:	456.9 KB ID:	788320
    Changelog v2.0:
    • newest su binary installed
    • installed patched SuperSu 2.82, which does not require updating
    • USB debugging enabled by default, full AdbShell support, disabled Selinux
    • UI animation speed set to 0.5
    • Noise reduction disabled
    • tcp buffer tweak for slow internet
    • Auto Frame Rate (afrd) service management software installed
    • autohide tray and navigation bar
    • Chromecast screensavers with cut ads
    • added a saver control section in the side settings
    • two voice searches of your choice (standard and AndroidTV)
    • firmware cleared of unnecessary files
    • Built-in advanced TWRP recovery 3.2.3-1 with additional features for backup
    • 13 WiFi channels
    The following applications are added:
    • ES Explorer
    • Power-menu to enter TWRP
    • Smart YouTube
    Want to buy me a beer?
    Donation Link Press Here
    Download:
    DOWNLOAD HERE THE GT-King Pro VolksWare by Sasvlad v.2.0 English
    DOWNLOAD HERE THE GT-King Pro VolksWare by Sasvlad v.2.0 Russian
    Install instructions:
    The firmware is implemented in the img version, for the "clean" flash via cable with the Amlogic's USB Burning Tool.
    You can also use the firmware method via SD (at least 4GB). Prepare an SD card specifically with Amlogic's Burn Card Maker.
    • Refer to Beelink own tutorial how to flash this box!
    Enjoy it!
    Hi I accidentally installed your firmware on to a basic? Beelink GT King model  (not a pro box). It's old firmware was 906P0 and it's serial no. B992. The performance and speed has increased 100% with your rom compared to the old rom from Beelink. However, the usb3 sockets only work with usb2. I tried connecting a Seagate 2TB usb3 to the port it would not recognise it. I also tried a usb3 stick 128GB and it did not recognise it. I was amazed it worked at all. I think there is hardly any difference in the hardware, perhaps none? just a different rom?????
      RE:?  GT-King Pro VolksWare by Sasvlad v.2.0 (Standard Android 9.0 Pie)
      Hi I accidentally installed your firmware on to a basic? Beelink GT King model?  (not a pro box). It's old firmware was? 906P0 and it's serial no. B992. The performance and speed has increased 100% with your rom compared to the old rom from Beelink. However, the usb3 sockets only work with usb2. I tried connecting a Seagate 2TB usb3 to the port it would not recognise it. I also tried a usb3 stick 128GB and it did not recognise it. I was amazed it worked at all. I think there is hardly any difference in the hardware, perhaps none? just a different rom?????
        Update
        If you become become a super user and then a developer, then go to usb config and pick p2p , it worked for me. Thanks to Sasvlad you are best coder I have seen so far.
          Also switch off tethered hardware.
            This box is a nightmare. I can't get the usb3 to work. I am returning it to the vendor. I have tried 3 different roms and they are all full of bugs!!!! and the GT King rom is the worst!
              Update: [ROM] Beelink GTKing VolksWare by Sasvlad v.2.0_906P0 Hi, I present to you another ROM for this box. I've made 4 different ROM's for these boxes two for boxes starting with SN: 922X & SN:95X2 and another two for SN:B922 (English and Russian localization for each) Many thks to Beelink (https://forum.freaktab.com/mem
                Thanks for that I have tried it and it's the same problem every time the usb3 port does not work. If you have any ideas they would be much appreciated Thanks again for all your time and energy you have put into this bag of bones project!
                  Не получается скачать вашу прошивку почему.
                    Hi Savslad,
                    my TV Box is GT King Pro 6B9H. Is this rom compatible with my box?
                      Originally posted by smailey View Post
                      Hi Savslad,
                      I don't know, but you can try. Nothing irreparable will happen.
                        не скачивается прошивка?
                          How can I get this soft ? Links are not working!
                            The same, both links are broken
                              Good
