Beelink T4 New Desktop Mini PC - Black 4GB RAM + 64GB EMMC
    Intel Atom x5 - Z8500 Intel HD Graphics 600 / 4GB RAM + 64GB EMMC / 2.4GHz + 5.8GHz WiFi / 1000Mbps / 2 x USB3.0 / BT4.0 / Support 4K 30fps
    Description as found
    Beelink T4 Mini PC comes with chipset Intel Atom x5 - Z8500 CPU, and it provides you a smooth experience to watch the videos or play games, with USB 3.0 port, make the transmission faster than before. Its faster speed gives you higher working efficiency. On the other hand, T4 is also the best choice for your family entertainment, you can have your family members play games or watch TV shows together.
    Main Features
    ● Powerful processor
    Equipped with Intel Atom x5 - Z8500 CPU which is advanced in image processing and computing. Its high machine configuration gives you ultra-fast running speed and smooth image processing performance. With the HDMI 2.0 data output, it makes sure you can enjoy 4K x 2K Even 3D HD movies.
    ● Advanced operation system
    Support for fast and powerful Win 10 operation system. Perfect for working, watching TV and playing games. Rapid, stable configuration coupled with the highly Win 10. Support dual-screen, reduce the waiting time, improve your work efficiency. Say goodbye to the System freezing and buffering.
    ● Convenient to use
    Support multiple connections such as Ethernet 1000Mbps, standard RJ 45, Bluetooth 4.0 and 2.4 / 5.8GHz WiFi. It is very easy to install, as soon as you plug in the power supply and connect the box to your WiFi or else way, you can Watch whatever you like. Users can surf the Internet with browsers and have a communication with the world through kinds of APPs, like YouTube, SKYPE video call, MSN, facebook, also the hot films and TV shows can be searched at any time.
    ● Practical multi-media player
    A practical home streaming media player, feel free to enjoy all your favorite movies, sports shows, and entertainment programs. And you can also save the games, movies and TV shows you like, support the SD card extended to 128GB ( not included ).
    Performance Parameter
    - Work environment: -10 - 45 Deg.C, 30 - 90 percent humidity
    - Storage environment: -20 - 60 Deg.C, 10 - 90 percent humidity
    - Built-in CR2032 210mAh battery
    ​​​​​​​Specification as found
    Brand: Beelink
    Model: T4
    Type: Mini PC
    System: Windows 10
    Core: Quad Core
    GPU: Intel HD Graphics 600
    RAM Type: LPDDR3
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 1080P,4K,DAT,FLV,MKV,MOV,MP4,WMV
    Audio format: AAC,AC3,MP3,MPEG,OGA,OGG,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac, Dual-band WiFi 2.4GHz/5GHz , Dual wireless antenna
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,DP,HDMI,Microphone Jack,RJ45,USB2.0,USB3.0
    Language: Multilanguage
    HDMI Version: 1.4
    Other Functions: Others
    HDMI Function: HDCP
    Power Consumption.: 12W
    RJ45 Port Speed: 1000Mbps
    Power Type: External Power Adapter Mode
    Power Input Vol: 12V
    Suggest Input: 12V 2A
    Power Adapter Input: 100-240V / 50-60Hz
    Product weight: 0.2500 kg
    Package weight: 0.6600 kg
    Product size (L x W x H): 10.60 x 10.60 x 1.77 cm / 4.17 x 4.17 x 0.7 inches
    Package size (L x W x H): 14.60 x 12.40 x 7.00 cm / 5.75 x 4.88 x 2.76 inches
    Package Contents: 1 x Mini PC, 1 x Power Adapter, 1 x Mini PC Bracket, 1 x English User Manual
    Gearbest:
    $98.99 coupon code: GBCN85T4:
    https://www.gearbest.com/mini-pc/pp_009989099374.html
    Another day another Intel box for your viewing Pleasure
    This time at the other end of the scale
    The all singing and dancing Beelink T4 Z8500 CPU 4GB and 64GB Ram
    Lets not dilly about and have a look at what we have:
    Brand: Beelink
    Model: T4
    Type: Mini PC
    System: Windows 10
    Core: Quad Core
    RAM Type: LPDDR3
    5G WiFi: Yes
    HDMI Version: 1.4
    HDMI Function: HDCP
    On with the Show and tell:
    All packed and Presented in a typical Beelink way
    The Usual 2 HDMI cables and the Vesa type Bracket and associated bits: all the things needed
    Ports to bee seen, good to see couple of USB on the front,headset jack and power button.
    Rear: Ethernet, DP Port HDMI and another USB, Power Socket
    Side: Another USB and Vents
    Other Side: More vents and the reset button
    Remove the Base plate can see with RTC and a Slab of Alloy, top of ports etc
    Other side even less to see: WiFI and BT Antenna attached to Lid
    I will get this all back together and do a few tests and see what it can do.
      As per the normal with Windows, The Beelink T4 we have the OOBE Windows all good and real
      Easy to customise to your location language etc, and activates
      After 10~ 20 or so minutes from first power on all up and running and Windows is alive.
      Being 4/64GB Storage is tight but a USB HDD or Stick will add as much as you think you
      will need, and become part of storage, happy to see we have a few extra USB ports around the place.
      The Beelink T4 is running the latest WIN10 V1903 hopefully only a few updates to bother with at this stage.
      There is no need to update, but I find its a quicker way to finding what they have broken instead of
      waiting for a few days
      Being a 4/64 Z8500 if you have never owned a Windows PC then this is a good Budget starting point.
      Yep it could have more but currently for around 100 Bucks I feel you cant go to wrong, If you want more as you know you need to pay everything is relative.
      It has Netflix HD and Normal 4k Playback, and all things Windows, No issues with your HBO or Foxtel or most any another paid streaming service,
      Linux I think it should will test for that later.
      Dual Display with HDMI and DP Port, 4 x USB3 ports Gig Lan Dual WiFi and BT.
      A good starter Small office, Home School work.
      Lets have a basic look around as per the norm and see how it does stuff.
      Windows Version:
      Installed and Activated:
      Doing Stuff:
      Device Manager main bits of Interest:
      Bit of an update to do: Not a lot.
      Dual Screen: working
      Watching some 4k did a Screen cap got both screens BIG
      After updates not much to clean:
        Well after a few unforgetful days, we are back in action lets things flowing again
        Optional Update to be had to get things to the latest and greatest:
        Stress test:
        Start:
        Middle:
        End: Slightly Truncated
        Speed test:
          Hello and thanks for your review.
          Hope you'll try it with Linux live usb, just to be sure there is no networking problems.
          Can you try to connect two 2.5 usb hdd to ensure it can power it.
          I'm interested to make a NAS server with 2hdd + torrent VPNed seedbox
            I would ensure the HDD had their own power supplies or maybe run of a powered HUB....
            See how we go next day or so with Linux etc
              Created a Mint USB using Rufus
              network looking ok
                Thanks a lot for your time.
                Did you also try wifi with mint?
                  Yes 2.4 and 5g seen and connects and does its thing
                  Bit of deal at Amazon with Beelink
                  https://www.amazon.com/gp/mpc/A2YYHZUZGAB2PQ
                    I bought it yesterday for 89€ at gearbest with GBCN85T4 coupon code.
