[Universal ROM] GS-King X and GT-King Pro AndroidTV by Sasvlad (Android TV 9.0 Pie)
Originally posted by ddogishere View Post
I can't write to /system/bin : Permission denied
I don't recall about the sasvlad's 914 ROM, but I would assume it was the same.....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Right now I am using the stock firmware Build 915PO. The "root" switch is enabled. I copied a file to the system/bin using the Xplore app without any issues. In that app you do have to enable the root access setting to give it read/writing ability.......
What this ROM needs is a stay awake app for the hard drives. There is an open source program for this but not Android, it runs on Linux.
I have now gone back to using the Superceleron ROM as this one closed Kodi while playing a video. I'd call that a crash. Not meant for the GT King though so....Last edited by Charlie_Boy; 25 July 2020, 14:33.
No I'm using Termux(Android Terminal command)
I believe the system 'root switch' is pseudo root as when using Termux to mount GDrive in Emulated/0/GDrive: Permission Denied.
I can unroot with impactor app but need help to install permanent root that gives full root without boot to recovery every time like Magisk. Also I tried it with Twrp using R2-SuperSu version but I think I need a signed one for the GS-king.
Thanks.
Originally posted by ddogishere View PostHi my GS-King keeps refreshing to 1080p60 screen resolution even though I have a 4k tv. I do select 4k30(no 4k60 option) but goes back to 1080p60 when tv is turned off/on.
Any ideas please? Thx.
Thx.
Is anyone else having the same issue as i am? Here is a video of my issue:https://www.youtube.com/watch?v=P_ZglidhERI
Thx.
There are currently 1869 users online. 0 members and 1869 guests.
