600Mbps, Dual Band Dual Antennas, 1 WAN Port + 2 LAN Gigabit Network Port, 2GB RAM + 16GB ROM, 2.4GHz 5GHz Dual WiFi
Main Features: as found
● Strong signal, wide coverage, stable network
● CPU: Amlogic S905W Quad Core ARM Cortex A53 @ 2GHz
● GPU: Penta-core Mali-450MP GPU @ 750MHz
● RAM: DDR3 2GB
● Memory: eMMC 16GB
● WiFi: not / connect router
● Material: plastic
● HDMI: 1 x HDMI / 4K x 2K UHD output, HDMI 2.0A
● AV port: 1 x AV out / 480i / 576i standard definition output
● USB Port: 4 x USB / USB host port
● IR reciver: 1 x IR reciver / remote reciver connect
● RJ45: GbE interface input / share with routers
● TF Card: 1 x TF Card, support 4GB/8GB/16GB/32GB/64GB
● Power: DC 12V / 2A
● LED indicator: working: blue, standby: red
Gearbest
