Xiaomi Mi 3 TV Box International version - Singles Day Special
    Hi
    There are several specials for the Mi Box 3 on Aliexpress at the moment.
    The price will go back to normal in 4 hours.
    Search for Mi Box 3 on Aliexpress
    If you are looking for a cheap device that is Google Certified and can play 4K Netflix, now is the time before it's too late.
    Even cheaper than the FireTV 4K Stick.
    A good price for people outside the US where the device usually sells for over $60.
    Here are 2 links for $46 so far:
    https://www.aliexpress.com/item/3269...chweb201603_55
    https://www.aliexpress.com/item/3276...chweb201603_55
    Special is now finished.
    Hope at least it helped some people since it was very cheap.
    Now Nokia is also in smart TV competition
