Pleas help add root to system.img
    Hello.
    I create my own light custom rom based on last Neomode rom 1.7
    I finished all but can't add root.
    pleas help!
    this is link for system.img
    Any help?
      Re: Pleas help add root to system.img
      You can download superuser.zip or supersu.zip from xda, the zip used to install it with cwm, unpack it, and add the files inside to the correct location, add the permissions, and vuala, you have the device rooted. To check the permissions needed take a look at updater-script file inside the zip, it contains a edify script and looking on it you will see the permissions needed for the files.
      leolas.
      My devices:
      Gearbest.com)
        I know how root the device but i can't add root to system.img .
        I build my custom rom and have finish but, can't add root ( lack of knowledge )
        Build with RK3xxx_firmware_tools.4.0.12 and when i add root and flash my device
        superSU app show "here is no su binary intaled and supersu cannot install it this is a problem!"
        pleas help - my device is mk809iii
