How could I recover It?
Vontar TX92 bricked. How can I recover It?
My Vontar TX92 stuck on home screen, so I have tried to disconnect the power plug and reconnect It again, but unfortunately my TX92 stuck on boot loading. I have tried a couple of time to restart It and now seems totally bricked, no display, and not even power button led.
How could I recover It? -
Originally posted by AndreaF View PostMy Vontar TX92 stuck on home screen, so I have tried to disconnect the power plug and reconnect It again, but unfortunately my TX92 stuck on boot loading. I have tried a couple of time to restart It and now seems totally bricked, no display, and not even power button led.
first you need the correct FW , do you have the Stockrom ??? , then look for , "shortPins" and Maskrommode , this will help you out ,
good luck / gefattern
Hi ,
I haven't installed any mod rom but I haven't the original rom image. Could you provide me some link (also for the matter "hortPins and Maskrommode)? Thanks!
i dont have this Box , so i can not give you Link for FW , here are some useful Infos :
Hi Everyone We have created this thread to collect all the NAND pin Short to Mask ROM Mode locations for all our members. Because firmware comes on android
I was able to make the TV Box detectable by "USB_Burning_Tool_v2.0.8_x86" since I haven't found any Vontar stock image I have tried to flash Vorke Z6 / Tanix TX92 Stock Nexus ROM.
but the flash process stop at 2% with update error:
[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
I don't know if this error is due to the fact the firmware isn't compatible with Vontar TX92 (3G RAM 32G ROM). I have chosen this firmware because I haven't fount anything for Vontar TX92 and seems It has basically the same hardware of Tanix TX92 etc.
Originally posted by AndreaF View PostI was able to make the TV Box detectable by? "USB_Burning_Tool_v2.0.8_x86"? since I haven't found any Vontar stock image I have tried to flash? Vorke Z6 / Tanix TX92 Stock Nexus ROM.
one positiv , one nagativ News , do you know what Wifichip is used ??? ,
for sure the Rom was wrong , best to use Stockrom , look here for some Info :
sure you can find it here on FT too ,
greetings / gefattern
The wifi chip is Cdtech 201023
There are currently 2601 users online. 1 members and 2600 guests.
