First.. what version xbmc are you running?
second.. did you make a 'playercorefactory.xml ?
3... what version of mx did you install 'free' or 'pro' ?
if you installed a xbmc version that has external support.. enabled
-then its browsing to the movie link.. click on scroll button, play using : (this list the video player options)
--older version like 12 have this symbol/button '>'
Reason: typ0, link added
thanks for reply .. running xbmcapp-armeabi-050713.apk - no playercorefactory.xml to my knowledge.
The MX installed is the FREE version.
Live as if you were to die tomorrow. Learn as if you were to live forever
