Unbrick V88 TV BOX
Originally posted by IliasGR View PostHello guys,i had some boot problems so i tried to re-add the firmware but i failled and from then there is not appearing the red/blue light and it shows nothing on the tv.How to unbrick it?
https://i.imgur.com/ZXUlg6H.jpg
you can try the "shortPins" Way or try it with SDCard Way , look here :
for SDWay you need another Tool , not sure if it supports RK3229 ,
good luck / gefattern
Hi ,
https://ugoos.net/blog/reflashing-in...device-bricked
Thanks for the reply! I ve got some questions.If i choose the pin method,should i plug the tv box on the pc while doing it?If i choose the second method,how am i gonna make it work?Keep in mind that no red/blue light is appearing,
follow the steps and restore your Box , yes about your Question , short , hold it , connect USB , connect Power , if all is good you hear the Sound of Pc and can stop short , after this restore with Tool , dont forget to install RK Drivers , possible the newest , later i upload a working SDCard Tool for your needs ,
Hi ,
Originally posted by IliasGR View Posti plugged it and android tool says found one maskrom devie but when im going to add the firmware it appear the following "wait for loader fail:
i shall upload the SDCard Tool , but i think this is a special Problem , has to do with "uboot" i think , not sure how to fix it , hope you can get it with SDTool , do you know what "Loader" Version you have ??? ,
Hi ,
here is the RKSDTool & latest Drivers :
Hi ,
There are currently 2870 users online. 1 members and 2869 guests.
