POLOROID diamond 8 mid0818
Originally posted by 3rshhh View Postthis comes from LAZADA philippines and its too slow i want to root it, i dont care if its void the warranty, i just want to make it smooth to touch, i cant see any ROM to update it its only ICS. i do played zombie tsunami but became slow..... what do i need to do
That's at least a start. Perhaps someone will pick up ROM development for you....
thnks for the reply
Originally posted by elektrik View PostHonestly, I'd start by posting as much of the specifications of the tablet that you know (cpu, memory amount, etc.). Then I'd check to find if there's a factory/stock ROM that perhaps can be modified (the Polaroid website in the U.S. is different for other countries, so yours is not listed), THEN I'd start researching how to root, etc. here and on Google-there's plenty of information on that available to be sure.
the model number is MID0818
android ver. 4.0.4
baseband ver 1.5_130412
kernel ver 3.08+ inet_hgb@supperFAE #69
Fri May 3 11:17:41 CST 2013
Build number A13_8V_m805BV_1305021.20130504
PLS do hope someone can tell me how to upgrade by the way i unlocked already the ROOT
Originally posted by 3rshhh View Postthe model number is MID0818
android ver. 4.0.4
Originally posted by elektrik View PostSounds like it *might* be an Allwinner chip, but without a stock image and/or the actual tablet, I wouldn't ever be able to tell for sure.
Originally posted by 3rshhh View PostMr. electric tell me what to do how to gave you the IMG you want to see the rooting tool said that its already rooted but i dont see SUPER SU so what i did is ROOT unlocker now its rooted i have super SU and i want to change the rom so it can be smooth to touch and a bit faster thanks hope to hear from you soon
Originally posted by elektrik View PostThe URL below lists stock U.S. Polaroid ROM's, for our tablets here in the states. Your mission is to find the equivalent ;-)
http://southerntelecom.com/polaroidsupport/firmware/
its only MID800 the one who is listed there im afraid to brick my tablet if i will try to choose this version
mine is MID00818
Originally posted by 3rshhh View Postits only MID800 the one who is listed there im afraid to brick my tablet if i will try to choose this version
mine is MID00818
*you* have to find the equivalent support site in Europe for your tablet. The URL I gave you was only an example.
hello ts im from Philippines too... ahm i also have the root access but unfortunately I have bricked my phone and it stucked in boot logo... i tried to install cwm recovery but i figured that it's not compatible with my tablet. i hope you or someone can help me providing recovery img or something.. thanks God bless!
There are currently 2764 users online. 0 members and 2764 guests.
