Please help, my GT1 isn't working well
    Hi there,
    i'have got a Beelink GT1 MINI TV BOX Android 8.1 Quad Core 4+64GB since few time. And at the first time i switch on it i got problems
    Firstly, the box didn't want to go, and show me a unstopable "please wait". I figured it out with a SD card. Now, it works with a Freaktab system.
    So it works well except :
    - The ethernet doesn't want to work. The link is well connected but not detected, even if the wifi is OFF. Have tried with an other link, the same.
    - I tried to install a wifi with in static mod, but it doesn't work. The box tell me so "the wifi is connected but without internet access"
    - With Kodi, i don't have the title of tv programms, i tried to follow a tuto about but i'm stopped when i need to find in the M3U adresse the port number, my M3U adresse doesn't have it...
    - I can turning off the box, but i can't tunring off without to put off/in the A/C adaptator. When it's off, the On boutton of the switch (the telecommand which is delivered with GT1) doesn't seems to work
    One detail : please excuse my english but i'm french..
    Thanks et bye, passez un bon lundi !!
    Originally posted by halfbrain View Post
    Hi there,
    i'have got a Beelink GT1 MINI TV BOX Android 8.1 Quad Core 4+64GB? since few time. And at the first time i switch on it i got problems
    Hi ,
    think you must use a better Rom , there a several CustomRoms to find here on FT , a better Powersupply with enough "mah" Example : stock = 5V/2000mah , better = 5V/3000mah makes a difference .
    Hope you can find a working Rom , but remember it must support your Wifichip , i think they used two different Chips , but not sure , for more Info read the GT1 FW Threads ,
    good luck / gefattern
      My charging case is not charging the left earbud, only the right ear. Seems like the pogo pin Great Clipsconnector has gone missing for the left earbud.
