The rom is great but the only problem I have is that when I try to format my external SD card or format the SD card to internal, the process stops with the message "unfortunately, settings has stopped".I've tried clearing cache and data, and even forced stop.
I think this is is an issue with the RR rom as many people have commented the same issue on another website.
Wondering if anyone knows how to fix this problem?
I also tried reflashing the rom. Does anyone know if there is another rom I can try, which is android 6 or higher?
Davimin
