mk808b flash Finless 2.1 error "backupFile is non existed"
    tried to flash a new mk808b -using flash tool1.37
    erased nand all went well -then tried to flash Rom and get error "backupFile is non existed"
    Pls help
    If you check the box backup ! the tool search a backup.img ! uncheck this box and the flash go !
      yeah thats what I did -just unchecked backup and it worked but what have I lost?
        The backup line has to be there for the flash tool to work....but there is no backup.img.
        Just uncheck the backup box and you are good to flash.
        Randy
        Randy
